How to re-compile the samples project in Visual Studio?
8628
11
03-11-2024 05:45 PM
LuigiMussardo
Hi All,
I've been trying to compile the samples project without success.
  1. I've put the plugin (v1.4) inside the Plugins folder
  2. generated the visual Studio file
  3. open the solution in visual studio
  4. set the sample_project as startup project
  5. development editor
  6. win64
I tried build, rebuild, clean+build and I always get the same output log:
Build started at 00:40...
1>------ Build started: Project: sample_project, Configuration: Development_Editor x64 ------
1>Build started 12/03/2024 00:40:59.
1>Target Build:
1>  Using bundled DotNet SDK version: 6.0.302
1>  Running UnrealBuildTool: dotnet "..\..\Engine\Binaries\DotNET\UnrealBuildTool\UnrealBuildTool.dll" sample_projectEditor Win64 Development -Project="Z:\TEMP\new\sample_project.uproject" -WaitMutex -FromMsBuild
1>  Log file: C:\Users\info\AppData\Local\UnrealBuildTool\Log.txt
1>  Building sample_projectEditor...
1>  Using Visual Studio 2022 14.36.32545 toolchain (C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.36.32532) and Windows 10.0.22621.0 SDK (C:\Program Files (x86)\Windows Kits\10).
1>  [Upgrade]
1>  [Upgrade] Using backward-compatible build settings. The latest version of UE sets the following values by default, which may require code changes:
1>  [Upgrade]     bLegacyParentIncludePaths = false               => Omits module parent folders from include paths to reduce compiler command line length. (Previously: true).
1>  [Upgrade]     CppStandard = CppStandardVersion.Default        => Updates C++ Standard to C++20 (Previously: CppStandardVersion.Cpp17).
1>  [Upgrade]     WindowsPlatform.bStrictConformanceMode = true   => Updates MSVC strict conformance mode to true (Previously: false).
1>  [Upgrade] Suppress this message by setting 'DefaultBuildSettings = BuildSettingsVersion.V4;' in sample_projectEditor.Target.cs, and explicitly overriding settings that differ from the new defaults.
1>  [Upgrade]
1>  [Upgrade]
1>  [Upgrade] Using backward-compatible include order. The latest version of UE has changed the order of includes, which may require code changes. The current setting is:
1>  [Upgrade]     IncludeOrderVersion = EngineIncludeOrderVersion.Unreal5_0
1>  [Upgrade] Suppress this message by setting 'IncludeOrderVersion = EngineIncludeOrderVersion.Latest;' in sample_projectEditor.Target.cs.
1>  [Upgrade] Alternatively you can set this to 'EngineIncludeOrderVersion.Latest' to always use the latest include order. This will potentially cause compile errors when integrating new versions of the engine.
1>  [Upgrade]
1>  Determining max actions to execute in parallel (14 physical cores, 20 logical cores)
1>    Executing up to 14 processes, one per physical core
1>  ------ Building 4 action(s) started ------
1>  [1/4] Compile [x64] Module.sample_project.cpp
1>  Z:\TEMP\new\Source\sample_project\Routing\RouteManager.cpp(70): error C4459: declaration of 'TraceLength' hides global declaration
1>  Z:\TEMP\new\Source\sample_project\Measure\Measure.cpp(20): note: see declaration of 'TraceLength'
1>  Z:\TEMP\new\Source\sample_project\Routing\RouteManager.cpp(146): error C4459: declaration of 'TraceLength' hides global declaration
1>  Z:\TEMP\new\Source\sample_project\Routing\RouteManager.cpp(257): error C4459: declaration of 'TraceLength' hides global declaration
1>  Total time in Parallel executor: 4.24 seconds
1>  Total execution time: 4.93 seconds
1>  C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.MakeFile.Targets(44,5): error MSB3073: The command ""C:\Program Files\Epic Games\UE_5.3\Engine\Build\BatchFiles\Build.bat" sample_projectEditor Win64 Development -Project="Z:\TEMP\new\sample_project.uproject" -WaitMutex -FromMsBuild" exited with code 6.
1>Done building target "Build" in project "sample_project.vcxproj" -- FAILED.
1>
1>Done building project "sample_project.vcxproj" -- FAILED.
1>
1>Build FAILED.
1>
1>Z:\TEMP\new\Source\sample_project\Routing\RouteManager.cpp(70): error C4459: declaration of 'TraceLength' hides global declaration
1>Z:\TEMP\new\Source\sample_project\Routing\RouteManager.cpp(146): error C4459: declaration of 'TraceLength' hides global declaration
1>Z:\TEMP\new\Source\sample_project\Routing\RouteManager.cpp(257): error C4459: declaration of 'TraceLength' hides global declaration
1>C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.MakeFile.Targets(44,5): error MSB3073: The command ""C:\Program Files\Epic Games\UE_5.3\Engine\Build\BatchFiles\Build.bat" sample_projectEditor Win64 Development -Project="Z:\TEMP\new\sample_project.uproject" -WaitMutex -FromMsBuild" exited with code 6.
1>    0 Warning(s)
1>    4 Error(s)
1>
1>Time Elapsed 00:00:05.51
========== Build: 0 succeeded, 1 failed, 10 up-to-date, 0 skipped ==========
========== Build completed at 00:41 and took 06.048 seconds ==========
and error list:
I am stuck and can't do anything..
Does anybody have any hint on how to get it working?
Many thanks,
Luigi
AShahbaz
This should now be resolved in the main branch as well. So you can simply pull the main branch or get a new copy of the Samples repo. Let us know if you are still having issues with this.
LuigiMussardo
It finally works! Thank you all for your support!
Luigi
