How to modify a layer in a blueprint
3055
6
10-08-2022 02:53 AM
threeooo
Can I edit a layer in a Blueprint? Like transparency, visibility, or adding and removing layers.
I tried using the Create Arc GisImage Layer with Properties function and it didn't work.
I don't know if I'm going in the wrong direction.
ArcGis->MapComponent->GetLayers,I can get an array, but I don't know how to convert each item to get the layer I want.
2 Solutions
Matt_Nelson
Esri Alum
If you want to modify layers instead work with the layers list on the View. In other words MapComponent->GetView()->GetMap()->GetLayers
threeooo
Get the Map Component, connect the Get Map() function, and use the GetLayers() function. At this point, we can get all the layers loaded. To get a specific layer, use the GetSize() function.
My method:
All layers: GetMapComponent() -> GetMap() ->GetLayers()
One layer: GetMapComponent() -> GetMap() ->GetLayers() ->At(Position)
I also have a problem: GetMapComponent() ->GetView()-> GetMap(), which can also get layers, so what the GetView() function does, I can't understand at the moment.
threeooo
My fault . The example provided was found last night
yolanda_zyq
How did you solve it ? I tried to get layers from map component and it's not working
threeooo
My method:
Matt_Nelson
Esri Alum
threeooo
是的,你是对的。此方法将获取图层。
Matt_Nelson
Esri Alum
We will try to clean up the api so it is more obvious where it needs to be changed.
