Can't find function in UE when following the tutorials!!!
914
12-24-2022 02:22 AM
PhucTran1
Hello everyone!
I can't find the function when following the tutorials to display a map (Blueprints) have you guys removed the functions and not updated them on the website? Like the Map Component or Get View,...
The UI works great, but I need to generate the base map and add layers with blueprints for more flexible coding.
Please check again and update the tutorials on your website.
Thank you!
and1
by Esri Contributor
If you can't find a specific Blueprint node/function, you can try to uncheck the "Context Sensitive" option in the Context Menu. You should now be able to find the "Get View" node for example:
Ref: https://developers.arcgis.com/unreal-engine/maps/tutorials/display-a-map-bp/#set-up-a-basemap-and-se...
