ArcGIS Maps SDKs for Unreal Engine 5.1
7679
14
12-19-2022 12:00 PM
EstherPerron
I downloaded the newly release SDK version 1.1 for Unreal Engine 5.1 and I keep getting the following error  when using either a previous project file from 5.0 and a new project file created in 5.1.
The following modules are missing or built with a different engine version
ArcGISMapsSDK
ArcGISMapsSDKEditor
ArcGISSamples
Would you like to rebuild them now?
And once you select Yes, a second error says your project file could not be compiled. Try rebuiling from source manaually.
Anyone having this problem or know how to fix?
Thanks!
Alexandre-Notos
I've managed to compile the plugin for UE 5.1. There is only one compilation error that is easy to "patch"
In the ArcGISDataBuffer.h file under ArcGISMapsSDK\Source\ArcGISMapsSDK\Public\ArcGISMapsSDK\API\Unreal\
Change this code starting at line (185):
#if PLATFORM_COMPILER_HAS_IF_CONSTEXPR
		if constexpr (!std::is_trivially_destructible<T>::value)
#else
		if (!std::is_trivially_destructible<T>::value)
#endif
 to this:
 And optionally in ArcGISMapsSDK.uplugin change
"EngineVersion": "5.0.0",
to
"EngineVersion": "5.1.0",
MahmutHakkari
I generated a map with your plugin in unreal engine, i really liked the map and i want to use it for my project. The problem is that my main objective is that i want to be able to use the project without internet connection. Is there any possibility to download the maps that will be used in high resolution in order that the project can be runned on a computer without internet connection?
EugeneKolodinski
Hi, does it work in UE 5.1.1? I have the same issue and have no idea what to do. The whole my project consists from almost only C++ actors, so I definitely have built if with C++ things. All the plugins are installed to VS as well.
EugeneKolodinski
Is there any way to delete the message? Sorry, it was my bad, just right after I posted it here, I understood that all this time I was copying this into a wrong folder. Now it works correctly, sorry again!
mettard
Hello, what folder do you copy this plugin? Because i have same problem and maybe solution will be similiar to yours
