Cache map data after loading to prevent reloading
1647
05-08-2025 11:57 PM
RedRhino10
I have a xr viewer app that uses ArcGIS to visualise the ground map and terrain heights.
It works well so far, except when the camera head turns, the map which was out-of-frame before has lost a lot of its data and has to reload the data to get back to a high resolution terrain & visuals.
Is there some way to store high quality mesh/visuals once they've loaded and prevent the quality drops that I keep seeing?
Tags (3)
YifengChen
no ,i dont think there is any option that you can use out the box from the SDK, the closet thing you can try is to create a offline tile pack from Arcgis pro
