API request isn't working in Unity
143
Monday
JustinCresta
I'm using Unity 2022.3.42f and ArcGIS Maps SDK for Unity version 1.6.0.
I'm trying to follow the tutorial here: https://developers.arcgis.com/unity/maps/tutorials/display-a-map-api/
I have an API key, as shown in the first image. I have all the code copied. Both the map component and the camera are successfully created, but the map itself doesn't show. The inspector for the map component doesn't show the basemap, elevation, or layers either, as shown in the second image.
I have also tried using the map creator UI and samples and gotten similar results, making me inclined to believe that the issue is with my API key or request. When I check the developer credentials, it also says that the API key has had no usage.
Thanks for the help, sorry if this post was silly.
