Trouble installing ArcGIS Maps for Creative Cloud
1384
11-18-2021 03:14 PM
Michele_Montano
Hello,
I am having trouble adding the ArcGIS Maps for Creative Cloud. Which I downloaded from the following site,   ArcGIS Maps for Adobe Creative Cloud | Design with Data Driven Maps (esri.com)
I even contacted Adobe support because I could not find a way to install it without it being in the Adobe Marketplace. They suggested I contact the Developer because I was told that it may have been pulled for compatibility issues? I would appreciate any help and guidance on this issue.
Thanks!
KonstantinYakovenko
Good Morning Michele,
The file you downloaded is an installer, you double click on it to start the installation process. After you go through that installation process, the extension should show up under Window -> Extensions in the top Illustrator and Photoshop menus.
If you are still experiencing issues, could you elaborate on what issues you are experiencing in more detail including Adobe product(Illustrator/Photoshop) versions installed and whether you are on a Mac or Windows machine?
RAMALONEY
I have the same issue , Installed it as you suggested and when I lanch the extention it shows as a blank white window.
