Road Layer
1163
11-25-2021 07:22 PM
CassieMaynard
Hey Guys,
I have had some issues with the vector basemap not grouping the roads layer when using it in the Maps for Adobe plugin. I know that you can group by weight after its brought in to illustrator but when we are doing things like roundabouts that becomes an issue. Is there a work around where i can group all of the road types in the compilations pane or in ArcGIS online before bringing it into Illustrator?
Any suggestions will help
Thanks
JamesPoeschel
What basemap are you using? I can see roundabouts in illustrator after bringing it in as an AIX file:
If this doesn't work for you, I guess you could create different road layers by road type using your own roads layer in Pro.
