Lines showing up in export that aren't in file
1711
03-13-2023 12:51 PM
KatherinePriebe
Hello all, I am experiencing an issue when I export my map file to .pdf or .png. There are lines showing up that are not in the original image (see attached). I think it is because the hashed lines for the floodplain were created in ArcGIS Pro and something is happening upon export due to the complexity of drawing the hashed lines. Can anyone help with this? Thank you!
WendyGableCollins
Cartographer here (not Esri staff)
Those look like hatch pattern tiles that aren't being clipped to their shape. Can you define them with a color fill only in ArcGIS Pro and reassign the hatch pattern once in Illustrator?
WendyGableCollins
KatherinePriebe
Thanks for this suggestion. I will try it.
