Personal and File geo database difference of size
3026
05-22-2019 06:34 AM
OrkhanAbdullayev
I have .mdb (personal database) in ArcMap 10.3, I load files and it almost 2GB (the max size of personal gdb) and after I create File database (.gdb) and load again the same files but this time it took only 90mb. Am I doing something wrong or it is as it is?
another thing is when I copy my file gdb within the folder to another local disc, I need to set the data source link again, but for personal did not face this problem. (maybe it is because of personal database saves its data in access)
Egge-Jan_Pollé
Hi Orkhan Abdullayev‌,
Esri's Personal Geodatabase format is - as you already noticed - based on the Microsoft Access (MDB) database format. And MDB files tend to grow quickly as you use them, sometimes impeding performance. You might try a Compact and repair to see if you can shrink the MDB.
But in general a File Geodatabase, Esri's proprietary database format, will be more efficient and hence smaller in size.
Here you will find a nice comparison between the Personal and the File Geodatabase (and even the good old shapefile):
What is a Geodatabase? Personal vs File Geodatabase - GIS Geography
My advice would be to forget about the Personal GDB and stick with the File GDB...
HTH,
Egge-Jan
OrkhanAbdullayev
Hi Egge-Jan Pollé
Thank you for your fast reply and useful information also your valuable time.
Best Regards
Orkhan
Egge-Jan_Pollé
If you think your question is answered, you might mark the answer as correct.
