Decrease distance between vertices on line - Arcmap 10.3
2343
05-24-2019 04:12 AM
Labels (2)
OrkhanAbdullayev
Dear All,
I have a navigation lines (shapefile), the line contains vertices in every 20m, so it gave me big amount of data, I want to decrease the size between vertices to have less amount of points. Is there a way to do this in Arcmap 10.3 ? tried generalize tool and set the distance but it outputs only start and end points of line.
Thank you for your time.
OrkhanAbdullayev
Thank you for your reply, but the simplify tool also remove vertices on another line around of it in the given distance.
DanPatterson_Retired
If you select the offending line and run the tool, the tool will only process the selection leaving others untouched otherwise, the tool runs on all the geometries in the featureclass
