Iterator in pro doesn't iterate - produces 000229
2867
6
11-09-2017 11:05 PM
by Anonymous User
Not applicable
I have a model which contains an iterator.
The iterator reads from a network drive and outputs to a local location.
The local folder is defined as an inline variable, such as %localFolder%.
The output filename is defined as %Name%.
So in iterator it is %Folder%\%Name%
When I run the model it always runs the first tool (clip). The second tool casts a 000229, saying that it cannot open the file.
However the file exists in the proper location, with the right filename. I can import the file, it looks correct.
However the file is displayed as "FeatureClass".
I tried importing working models from ArcGIS basic, and rebuilding models.
As far as I can tell from the documentation there is no significant revisions in model builder, so I probabaly missedd something.
Hope someone solved this problem.
Error report:
Start Time: Friday, November 10, 2017 7:47:42 AM
Executing (Iterate Feature Classes): IterateFeatureClasses "P:\1012613 FTN Passiv RB Teknisk Rådgivning\06 Gennemførelse\Miljø\GIS\Shapes til konfliktsøgning" # # NOT_RECURSIVE
Succeeded at Friday, November 10, 2017 7:47:43 AM (Elapsed Time: 1.09 seconds)
Executing (Clip): Clip "P:\1012613 FTN Passiv RB Teknisk Rådgivning\06 Gennemførelse\Miljø\GIS\Shapes til konfliktsøgning\BeskyttedeStenJorddiger.shp" LH_FTN_Buffer1 C:\testmappe\Test3OS\BeskyttedeStenJorddigerclip #
Start Time: Friday, November 10, 2017 7:47:43 AM
Assembling Features...
Reading Features...
Cracking Features...
Succeeded at Friday, November 10, 2017 7:47:49 AM (Elapsed Time: 5.71 seconds)
Executing (Buffer (2)): Buffer C:\testmappe\Test3OS\BeskyttedeStenJorddigerclip C:\testmappe\Test3OS\BeskyttedeStenJorddigerbuf2 "3 Meters" Full Round "No Dissolve" # Planar
Start Time: Friday, November 10, 2017 7:47:49 AM
ERROR 000229: Cannot open C:\testmappe\Test3OS\BeskyttedeStenJorddigerclip
Failed to execute (Buffer (2)).
Failed at Friday, November 10, 2017 7:47:49 AM (Elapsed Time: 0.01 seconds)
Failed to execute (Model2).
Failed at Friday, November 10, 2017 7:47:49 AM (Elapsed Time: 7.27 seconds)
XanderBakker
Esri Esteemed Contributor
The message says that it cannot open "C:\testmappe\Test3OS\BeskyttedeStenJorddigerclip". But in what format is it?. Isn't there an extension (.shp) missing? Could you check if a file with that name exists in that folder. I see that it is created siccesfully in the clip before, but I think this might have created a shapefile called C:\testmappe\Test3OS\BeskyttedeStenJorddigerclip.shp
DanPatterson_Retired
that error has many sources, sometimes it is due to having 'background geoprocessing' enabled
http://support.esri.com/en/technical-article/000012177
You can check for other related errors on that error code, here is a general list
http://support.esri.com/en/Search-Results#search?q=error 000229
by Anonymous User
Not applicable
Thanks for the input.
I don't see how this should have any effect on iterator in ArcGIS Pro. You can't disable background geoprocessing in Pro as far as i know.
missed the pro... just saw it was in mapping and charting
XanderBakker
by Anonymous User
Not applicable
Thank you. That did the trick.
I appended .shp. So that the output of every tool is now %FTNtest%\%Name%.shp.
by Anonymous User
Not applicable
However.... In Contents (on the map) the feature classes are displayed as the inline variable name...
