How do i analyse the cells of a grid in connection with a layer?
959
10-28-2018 07:55 AM
UmweltzentrumDresden_e_V_
Hello, I have a question and i hope someone can help me. I used the tool "make grids and gesticules layers" to make a grid. I also have a layer, with the landuse in eastern germany. I now want to analyse for all of the grid cells, how much of the surface is used by the different landuse types (forest, settlement area....). Is there a possibility to do that?
Thanks a lot.
DanPatterson_Retired
You need to create a 'fishnet'
Create Fishnet—Data Management toolbox | ArcGIS Desktop
you don't do this in the layout view, but where the data resides in the dataframe or map view depending on whether you are using arcmap or ArcGIS pro
Thanks Dan,
I created a fishnet now. But how do i analyse all of the cells now? I´m using arcmap by the way.
I would look at the Analysis Tools in Arctoolbox, one of the overlay tools (perhaps intersect) might be appropriate
I found it now. The tool is "Tabulate Intersection". Thanks again, Dan.
Glad it worked out
