How can I convert my Story Map to a video?
2507
7
01-10-2018 10:51 AM
Labels (2)
DannyMiller
The goal is to have a kiosk at the Army Engineer School that will provide story map content on a large hallway display.
JohnPlunkett
HI Danny
Using Story Map autoplay mode | ArcGIS Blog
What you could do is use Storymap Autoplay
While it is in autoplay in your browser use a screen video capture software to capture the storymap
Then you could play the videos on repeat from the computer kiosk
ALternatively you may have Portal for ArcGIS Deployed  (This is ArcGIS Online behind the firewall) this could get you around the internet issue.
Good luck
DanPatterson_Retired
I shared this with https://community.esri.com/community/gis/web-gis/storymaps?sr=search&searchId=6cd8b2d4-b8c7-4094-8ca...‌ ... you are more likely to get responses from the people there
DannyMiller
Thanks Dan.
MeganMcClain
Do you have a story map already made?
DannyMiller
Yes, we have multiple story maps. Our goal is have the applications available for the Army Engineer students here at Fort Leonard Wood. Access to the internet requires an individual computer access card (CAC) and the network admin will not allow a "generic" CAC.  With restricted access to the internet, my thoughts were to convert the story maps to video and then display.  Any suggestions appreciated.
JohnPlunkett
HI Danny
Good luck
OwenGeo
Esri Notable Contributor
I'd echo John's recommendations. Use Camtasia or similar screen recording app to capture the story map in autoplay mode. Or if autoplay doesn't give you the experience you're after just manually browse through the story map while making a video.
Owen Evans
With Camtasia, you can do voice-over and/or captioning expanding your audience as well.
