Using SSURGO data
11938
12
06-30-2021 10:05 AM
Hope-Hauptman
I want to data for the soil hydrologic class for the Central Valley in California. Although I can see what I want in the living atlas: Portal -> Living Atlas -> USGS SSURGO -> Soil hydrologic Group, I cannot seem to figure out how to download and assemble that layer in ArcGIS pro as a shapefile or raster data? There seem to be two main ways of accessing SSURGO data.  I have tried both for one county just to see if I could get it to work but failed. Ultimately I would want this for 8 counties in the Central Valley...
Web soil survey
https://websoilsurvey.sc.egov.usda.gov/App/WebSoilSurvey.aspx
SSURGO Downloader
https://www.arcgis.com/apps/View/index.html?appid=cdc49bd63ea54dd2977f3f2853e07fff
jcarlson
The value for hydrologic group is derived from the gSSURGO map unit aggregated attribute table field Hydrologic Group - Dominant Conditions (hydgrpdcd).
The Soil Units layer contains the hydgrpdcd attribute in there. Most units have a value, but you can filter out those which have a Null value in the field easily enough.
- Josh Carlson
Kendall County GIS
jcarlson
Is there a reason you need the file downloaded locally rather than using the Living Atlas layer directly?
Regardless, if you're working with a Feature Layer (you'd have to use the Soil Units layer, rather than the hydro group imagery layer), you can interactively select the features in your area and just export them.
Or if you have your 8 counties, you could clip the soil units by those features and export that to a shapefile.
- Josh Carlson
Kendall County GIS
Hope-Hauptman
Hi Josh,
Thank you for your reply. Yes - that is exactly what I want to do clip the Living atlas layer but the living atlas layer does not seem to be 'clippable' so that is why I was searching for a downloadable raster or shapefile. I have tried using the clip raster tool with the living atlas layer but it fails (see image). Can you clip the living atlas layer?
You can get the SSURGO data here by state which would be a much smaller file so I am trying to do that but I guess you have to join attribute tables to see the soil hydrologic class?
https://nrcs.app.box.com/v/soils
jcarlson
I can clip the feature layer, but as I mentioned, I don't think you can do with w/ the Living Atlas' raster layers. I clipped the Soil Units feature layer without issue.
- Josh Carlson
Kendall County GIS
MichaelVolz
Esteemed Contributor
Josh:
Is there a Living Atlas URL to access a Soil service that you could use as-is in a web application instead of downloading the data onto a local server?
jcarlson
Hope-Hauptman
Yes I tried that too and it seems like it is working but it generates empty output...? Capture1.PNGCapture1.PNG
jcarlson
Try just selecting the soil units you want, then right-click the layer in Contents and click Data → Export Features. Does that work for you?
- Josh Carlson
Kendall County GIS
Hope-Hauptman
The soil units I want are Hydrologic classes and I don't see how select those...?
jcarlson
- Josh Carlson
Kendall County GIS
