Any concern that Living Atlas Federal USA data may go away or be taken down?
1591
12
02-06-2025 01:56 PM
CDFWGISAdmin
Hi, is there any concern that USA Federal-related data currently hosted by Esri in value-added Living Atlas services and data downloads may be at risk of going offline with the new federal admin trends of reviewing and/or discontinuing data access?  If so, any mitigation steps we can take to help ensure continued access?  Thanks for any insight.
SteveCole
Honored Contributor
The most proactive thing that you can do is enter URLs of concern into the Internet Archive to have them archive the site. I have been able to retrieve older datasets from as far back as the mid 2000s from some Forest Service sites this way.
As for AGOL / Living Atlas, I would not have any concerns about a layer disappearing if the "owner" who has published the service is ESRI or ESRI associated. In these situations, they have likely copied the data from the original source and are publishing from that point of origin. Some federal agencies such as the Forest Service have published their datasets through AGOL under their agency accounts and those could fall victim to whatever happens.
EllenNodwell_IntegraShare
I am seeing data loss from NOAA data (Tropical Product - historical storm data layers) -My last contact with the team at NOAA was 23 of January; something is wrong with the listsrv (no updates); no one responding and the data from ArcGIS Living Atlas is not coming in, either.
If someone from the Living Atlas team could let us know about what's happening, that would be awesome. If anyone has any news, that would also be helpful.
George_Thompson
Esri Notable Contributor
What specific product are you seeing the impact on?
Can you provide the URL?
--- George T.
BernSzukalski
Esri Frequent Contributor
I did a cursory check of all Living Atlas content (maps/apps/layers) in ArcGIS Online related to storms and specifically the historical storm content from NOAA. All seem to be fully operational with updates to feeds as of earlier today.
I am continuing to work with my map - the 2024 storms apparently migrated off of recent (?) - bottom line, what I added from Living Atlas back in July is not functioning. Here is the data I've been working with. Recent Hurricanes, Cyclones and Typhoons - Overview  I added it again - noted the update date is Feb 2025 (of that dataset publication).
In the meantime...
I checked the source listed in the info/meta data - found the Beryl data are available  here: https://www.nhc.noaa.gov/gis/archive_besttrack.php as shapefiles, so I downloaded the Beryl data and will build layers to publish myself so I can use them in my web experience application. I'll just have to do the re-work. Since my topic is Beryl, I'm not going to fret about the other 2024 US storms not being there for now.
I did try re-adding from Living Atlas, but the USA storms still do not show up - Helene, Milton... not there. Not the best sceen clip - but you can see the gold color symbols where the storms from Indian Ocean over across into Asia are present, nothing in GOM, Atlantic, or Pacific near the US states or territories, or below.
Guess it is good to know how far back "recent" actually goes in the definition of that dataset. It says past hurricane season, which in my thinking would be the one that included Beryl, and the rest to the end of the 2024 season... Maybe I'm off base here... You tell me.
So, if you see data for the USA in your map, let me know. I just added this freshly from Living Atlas into my map, so it should be what you are seeing. I have not applied any filters or anything to the data.
Hey Bernie - some of the layers in that dataset don't have any data - the wind swath doesn't have any data in it... Definitely something is going on with the feeds that make up that dataset...
BernSzukalski
Hi Ellen... Can you provide the link? I checked again and all the live feeds seem to be up-to-date and operating normally for me. I expect you are using this? https://www.arcgis.com/home/item.html?id=691f70d9a8b04cc2977467c2a2274d21
If so it seems to be operating normally and is up to date.
I also checked the Live Feeds Dashboard, all good there...
https://livingatlas.arcgis.com/livefeeds-status/
Hey Bern, Actually, that one is not the one - here is the link to the one I've been using specifically for hurricanes (Beryl was the topic of my application)... Recent Hurricanes, Cyclones and Typhoons - Overview
As of just a minute ago, the USA storms are still not present and the wind swath table is empty.
BernSzukalski
Ok, I see that now. Sending it on to the team...
