Is there a regular schedule for ESRI Demographics releases based on US Census data? For example if the 5-year ACS data is released in December, when would the ESRI Demographics 5-year ACS layer be released?
Thanks!
Solved! Go to Solution.
Have you seen these blogs:
https://www.esri.com/arcgis-blog/products/esri-demographics/announcements/whats-new-in-esri-u-s-demo...
https://www.esri.com/arcgis-blog/products/esri-demographics/announcements/whats-coming-in-esri-us-de...
Hopefully this helps you.
Thanks for the links regarding specific years. But I can't find a policy or documentation that says when ESRI updates the ACS layers in general. Is it within X number of days after the Census releases the ACS results?
Ah ok. I am not sure about that and cannot respond directly.
@LucyGuerra do you have any thoughts or insight into this?
Thanks Lucy!
