living atlas authoritative layers no longer available
961
09-03-2024 06:45 AM
HelenCooper
Hi, I've used a specific Living Atlas authoritative data layer in a large number of web maps and apps (the layer is "Indices of Multiple Deprivation (IMD) 2019" - https://livingatlas.arcgis.com/en/browse/?q=%22Indices%20of%20Multiple%20Deprivation%20(IMD)%202019%... )
This layer has now become unavailable, with an error message saying "This item is not currently available. The ArcGIS Online subscription associated with this item has been disabled."
All of my apps that use this layer are now requesting a user login.  All these apps are shared with everyone, so they do not normally need a login.
Any suggestions as to a workaround that doesn't involve removing these layers from every map would be very welcome.
Also, is there any way of finding out if this layers are likely to come back online again in the future?  It has made me much more wary of using living atlas content!
Many thanks,
Helen
LisaBerry
Hi Helen,
It looks like the layer is back in Living Atlas now: https://www.arcgis.com/home/item.html?id=45e05901e0a14cca9ab180975e2e8194. Since Living Atlas is built by the work of the GIS community, it could have been updated or was being worked on. There are also ways to quickly swap a new layer URL into your maps and apps using the AGO Assistant tool if needed: https://assistant.esri-ps.com/signin. Hope this helps!
LisaBerry
Hi Helen,
