Export LivingAtlas Features from Map Service
1213
06-17-2021 12:10 PM
LauraCarson
I'm trying to extract attribute and spatial data from the 2020 USA Diversity Index layer from LivingAtlas so that I can run an intersect on my area of interest boundary. This way I will be able to pull attributes from the 2020 diversity layer specifically for my area of interest. Since it is a map service, I am unable to work with the data to an extent other than just viewing it. Is the 2020 diversity data available for download or as a feature service?
Any help is greatly appreciated!
BernSzukalski
Esri Frequent Contributor
Hello Laura,
There is no feature layer equivalent of that layer for analysis, however you can enrich your own boundaries with the same attributes via Enrich Layer in the analysis tools, or via other apps that use the same service behind Enrich Layer such as Business Analyst web app.
If those options above are not satisfactory, and you want a flat data file with those attributes, you can connect with our data sales team at datasales@esri.com.
Cheers,
Bern
