unexpected fatal exception
1779
11-27-2023 11:35 AM
Deastman
Hi All,
I'm trying to load a table into my knowledge graph, and get an "Unexpected fatal exception"
An unexpected fatal exception occurred within this application. Execution should be terminated.
Start Time: Tuesday, 28 November 2023 4:59:29 AM
Failed at Tuesday, 28 November 2023 4:59:30 AM (Elapsed Time: 1 Seconds).
I've been able to load other tables into the knowledge graph, but it doesn't see to like this (and another) particular table.
I've tried csv's; xlsx'; a table in a geodatabase; a feature class in a geodatabase...
Through that troubleshooting, it would seem that the issue is with the Knowledge Graph itself, because I can successfully load the table into a new knowledge graph.
Any suggestions on why on particular dataset may throw this error and not another on one particular Knowledge Graph?
One of the datasets in question: CASA Australian Aircraft Register - Auto-Updated (kaggle.com)
Deastman
Digging into this a little further. Seems like the issue could be to do with one of the data fields... haven't worked out which one yet.
RichardParton
I'm experiencing the same issue, did you get any further with your investigation?
RichardParton
After some playing, the issue just came down to datatypes....In my case 2 Entities which I was trying to create a relationship between were of different types (one was Int and one was text) so after changing this so they were both text it worked as expected.
