Zooming to a extent.
1373
11-16-2012 11:34 PM
PrasannaRaghavendar
I have a map and the min longitude, min latitude, max longitude and max latitude values of a country.
Say the values are, -1.41382, 42.42873, 1.78659, 42.65601.
How should I zoom the map to this extent?
Thanks
Prasanna
PrasannaRaghavendar
I found out that doing this would zoom 🙂
var mercExtent =new esri.geometry.Extent({"xmin":xmin,"ymin":ymin,"xmax":xmax,"ymax":ymax,"spatialReference":{"wkid":4326}});// esri.geometry.geographicToWebMercator(geoCountryExtent) as esri.geometry.Extent;     var startExtent= esri.geometry.geographicToWebMercator(mercExtent);
So, the latitude and longitude values are the Geographic coordinates while the x, y coordinates are the WebMercator coordinates?
Thanks
Prasanna
PrasannaRaghavendar
Thanks
Prasanna
JanJeske
Hey if the spatialReference  of your map is the same as of the extent  you can try this.
map.setExtent(mercExtent );
Hope it helps you :).....
Here is a link to the API Reference
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi_start.htm
