Zoom to Query result
1654
01-07-2013 10:30 PM
emirates78John
Hi there,
I trying to find out what i have miss in the code.
Here the code :
function searchPrecinct(prct){
             presint = "";
  map.graphics.clear();
  dojo.byId("result").innerHTML = "";
  strwhere = "PRECINT_ID='"+ prct +"'";
  query.where = strwhere;
  qTaskPrecinct.execute(query);
  alert(strwhere);
  dojo.connect(qTaskPrecinct,'onComplete',function(fSetPrct){
   var resultFeatures = fSetPrct.features;
   if (resultFeatures.length==0){
    dojo.byId("result").innerHTML = "No record.";
    return;
   ixmin = 0; iymin = 0; ixmax = 0; iymax = 0;
   for (var j=0; j<resultFeatures.length; j++){ //get xy min max
    var graphic = resultFeatures;
    presint = graphic.attributes.PRECINT_ID;
    if (j==0){
     ixmin = graphic.geometry.getExtent().xmin;
     iymin = graphic.geometry.getExtent().ymin;
     ixmax = graphic.geometry.getExtent().xmax;
     iymax = graphic.geometry.getExtent().ymax;
    else{
     if (graphic.geometry.getExtent().xmin < ixmin) ixmin = graphic.geometry.getExtent().xmin;
     if (graphic.geometry.getExtent().ymin < iymin) iymin = graphic.geometry.getExtent().ymin;
     if (graphic.geometry.getExtent().xmax > ixmax) ixmax = graphic.geometry.getExtent().xmax;
     if (graphic.geometry.getExtent().ymax > iymax) iymax = graphic.geometry.getExtent().ymax;
   var newExtent = new esri.geometry.Extent();
   newExtent.xmin = ixmin - 6;
   newExtent.ymin = iymin - 6;
   newExtent.xmax = ixmax + 7;
   newExtent.ymax = iymax + 7;
   map.setExtent(newExtent, true);
   setTimeout( function() {
    newExtent.xmin += 1;
    newExtent.xmax += 1;
   }, 1000);
I failed to zoom into the result...
Anybody can help me?
HemingZhu
Hi there,
Here the code :
             presint = "";
  alert(strwhere);
    return;
    if (j==0){
    else{
   }, 1000);
I would try this:
             presint = "";
  alert(strwhere);
    return;
   map.extent =esri.graphicsExtent(resultFeatures)
emirates78John
hi hzhu,
thanks for the reply..
I already test your code but the result still same..not zoom to selected precinct..
I debug the code using chrome Javascript console, and it shows some error on the code.
Here I attached the image
[ATTACH=CONFIG]20564[/ATTACH]
