Zoom To Point??
1069
12-13-2011 07:22 AM
EmilyLaMunyon
Hello,
I am working on a map that displays data in a dojo grid and when the user selects the row, it zooms to the feature on the map. There are points and polygons and the polygons are zoomed to correctly, however, the points are highlighting on the map, but not zooming in at all. Any help would be greatly appreciated!!:o
} else if (searchType == "PointName") {
   var clickedTaxLotId = grid4.getItem(evt.rowIndex).POINT_NAME;
   var selectedTaxLot;
   dojo.forEach(map.graphics.graphics,function(graphic){
     if((graphic.attributes) && graphic.attributes.POINT_NAME === clickedTaxLotId){
    selectedTaxLot = graphic;
    //added this part to build infotemplate
     map.infoWindow.setTitle(graphic.getTitle());
     map.infoWindow.setContent(graphic.getContent());
    return;
   if ( selectedTaxLot.geometry.declaredClass == 'esri.geometry.Point' ) {
   //alert("Point");
   map.centerAt(selectedTaxLot.geometry);
   var sp = map.toScreen(selectedTaxLot.geometry);
   map.infoWindow.show(selectedTaxLot.geometry, map.getInfoWindowAnchor(sp));
   } else {
   //alert("Polygon");
   var taxLotExtent = selectedTaxLot.geometry.getExtent();
   var screenpoint = map.toScreen(selectedTaxLot.geometry.getExtent().getCenter());
   var mappoint = map.toMap(screenpoint);
    //map.centerAt(mappoint);
    //added by Emily
    map.centerAndZoom(selectedTaxLot.geometry,11);
   map.infoWindow.show(taxLotExtent.getCenter(), map.getInfoWindowAnchor(screenpoint));
JeffPace
Hello,
   var selectedTaxLot;
    return;
   //alert("Point");
   } else {
   //alert("Polygon");
    //added by Emily
That is because you are calling "centerAt" so all it does is pan.  Since a point has no Extent, you need to tell it what level to go to
you could try "centerAndZoom" i.e
map.centerAndZoom(pt, level)
EmilyLaMunyon
Thanks Jeff, that did the trick!!
