Zoom to Issues
4080
12
04-04-2017 06:51 AM
jaykapalczynski
Honored Contributor
I included the relevant code I think for this issue....
I have my Map
I am setting the spatial reference of the query results
Using the results to create a new graphics Layer
The Graphics are located in the correct position so that works fine...
BUT when the below runs it zooms off the coast of Africa.  I know this is a Spatial Reference issue but not sure where and how to set it...
Thoughts?
var extGraphics = graphicsUtils.graphicsExtent(map.graphics.graphics);
map.setExtent(extGraphics);
    //SET THE MAP
    var map = new Map("map", {
        basemap: "dark-gray",
        center: [-79.665, 37.629],
        zoom: 8,
        logo: false,
        showLabels: true
      // QUERY FOR County and Squad
      var queryTask = new QueryTask("https://vafwisdev.dgif.virginia.gov/arcgis/rest/services/Projects/Summons/FeatureServer/5");
      var query = new Query();
       query.outSpatialReference = {wkid: 4326}; //4326 //102100 //3857
       query.returnGeometry = true;
/// SNIP
      var countiesGraphicsLayer = new GraphicsLayer({opacity:0.75});
      //This is the click event for the graphics on the map
      countiesGraphicsLayer.on("click", selectGrid);
      map.addLayer(countiesGraphicsLayer);
/// SNIP
        arrayUtils.map(results.features, function(feature) {
          feature.setSymbol(symbol);
          feature.setInfoTemplate(infoTemplate);
          countiesGraphicsLayer.add(feature);
          var featureAttributes = feature.attributes;
          for (var attr in featureAttributes) {
            resultItems.push("<b>" + attr + ":</b>  " + featureAttributes[attr] + "<br>");
          resultItems.push("<br>");
        dom.byId(ActivePane).innerHTML = resultItems.join("");
        map.setExtent(extGraphics); ‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
/// SNIP‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
jaykapalczynski
Honored Contributor
thats it.....THANKS....I knew there was something small you could add....
SteveCole
Honored Contributor
Extent has a method called expand which will take the extent and enlarge it by the factor you specify.
jaykapalczynski
Honored Contributor
maybe I have to set the graphics layer to 102100
