Zoom to Graphic?
3498
08-03-2011 09:04 AM
JeremyAdams
Is it possible to zoom to a graphic?
My Application allows a user to enter a Parcel Number and use the findTask to create a graphic over the correct Parcel on the map.  But there are a lot of parcels so I would like to be able to zoom to the graphic.  Is this possible?
I've looked at centerAndZoom(point, lvl).  But I cant seem to figure out how to get a point from my graphic because its as Polygon not a Point.
Thanks for the help in Advance.
      //Executed to search for a Parcel with the correct Map and Page number
      function findParcel() {
        //set the search text to find parameters
        var searchText = dojo.byId("Map").value;
        if (searchText.length == 4) {
          searchText = searchText + "  " + dojo.byId("Page").value;
        else if (searchText.length == 3 ){
        findParams.searchText = searchText;
        findTask.execute(findParams, showParcel);
     function showParcel(results) {
        //symbology for graphics
        var polygonSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASHDOT, new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 0, 0, 0.5]));
        //find results return an array of findResult.
        map.graphics.clear();
        //Build an array of attribute information and add each found graphic to the map
        dojo.forEach(results, function(result) {
          var graphic = new esri.Graphic(result.feature);
            graphic.setSymbol(polygonSymbol);
          map.graphics.add(graphic);
derekswingley1
Yes, check out esri.graphicsExtent().
If your callback, pass your array of graphics to esri.graphicsExtent(), save the return value and then set your map extent using map.setExtent().
JeremyAdams
I tried that, but it seems to stop execution or break out of the showresults() when the new extent is created:        var parcelExtent = esri.graphicsExtent(results.features);
The application continues to function, but the graphic is never added to the map now.  I know I've got something wrong I just can see it.
        //create an extent matching the graphics of the parcel(s)
        map.setExtent(parcelExtent);
JeremyAdams
I have found the way to fix the zoom to graphic problem  I had to create a graphics layer and the pass the array in it to the zoomExtent() fcn.   This works great because I can zoom to a single or multiple parcels depending on input.
        //find results return an array of graphics in the graphicslayer.
        var graphicslayer = new esri.layers.GraphicsLayer();
          graphicslayer.add(graphic);
        var parcelExtent = esri.graphicsExtent(graphicslayer.graphics);
