Zoom to Graphic from Grid Crashes Chrome
3511
10-19-2015 03:11 PM
NathanaelVaughan
I have a page at
http://goldberg.mohavecounty.us/FEMA_Data/FEMA_Data.html
The page, to my knowledge, worked well until recently. In Chrome (I've tested on v. 46.0.2490.71 m), a function to zoom to a parcel based upon a search now crashes the browser. I've tried the same functionality in IE and Firefox and have no issues. Interestingly, if one zooms into the map using the zoom buttons shown on the map (not the scroll wheel), the issue does not arise.
Thoughts? Ideas?
To re-create the experience yoruself,
1. Accept the disclaimer
2. Click the "Search Parcels/TRS" tab
3. Search for a name. Anything common should work. "Smith" worked well for me.
4. Click on a result in the result grid.
5. Watch Chrome disappoint.
It appears as though the animation process seizes up. I added events for onupdatestart and onupdateend on the map - I know it gets past setting the extent to the graphic extent, but don't have much else to work with.
Can anyone confirm if the problem is present on older versions of Chrome?
SteveCole
Honored Contributor
It worked for me, using your directions, with Chrome Version 44.0.2403.157 m
Then I updated Chrome to Version 46.0.2490.71 m and now it hangs after it zooms to the parcel location. Weird.
ChristopherTotty
Please see the latest posts on this thread for a potential fix.
Zoom hangs when going from high level to low
