Zoom to extent of graphic array in Feature Layer not working
6433
06-30-2011 09:11 PM
GeorgieCassar
I can't work out why my map is not zooming to the extent of graphics in my featurelayer.
See at the bottom of this code where I try and use the esri.graphicextent method.
function initOperationalLayer(map) {
        var content = "<b>Street: </b>${Street_Name}, ${Suburb}<br/>"
                             + "<b>Pickup Time: </b>${Departure_Time}";
        var infoTemplate = new esri.InfoTemplate("Route 1 Details", content);
        var featureLayer = new esri.layers.FeatureLayer("http://gsportenf/ArcGIS/rest/services/Public_Access/MapServer/12",{
          mode: esri.layers.FeatureLayer.MODE_ONDEMAND,
          outFields: ["*"],
          infoTemplate: infoTemplate
        map.addLayer(featureLayer);
        var symbol = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,255,255,0.35]), 1);
        var renderer = new esri.renderer.SimpleRenderer(symbol);
        featureLayer.setRenderer(renderer);
        map.infoWindow.resize(300,100);
        var zoomExtent= esri.graphicsExtent(featureLayer.graphics);
        map.setExtent(zoomExtent);    // THE MAP IS NOT CHANGING !!!
HemingZhu
          outFields: ["*"],
To my understanding, you set up featurelayer displayer mode as MODE_ONDEMAND. Without definition expression and time definition, the feature layer only display features at current map extent. So featureLayer.graphics in your statement actually are not the whole features in your featureLayer but the features in your current extent. So zoomExtent =YOUR CURRENT EXTENT !!. No wonder your map is not changing.
GeorgieCassar
I found out with an alert that my featurelayer.graphics.length was = 0 so I could not even access the graphics at all.
I found a post titled "unable to draw graphic" which helped me solve this problem.
If the layer isn't finished drawing before I try and zoom to the graphic extent, it simply won't zoom.
What I did was move the zoom code to an event handler using the onUpdateEnd event of the feature layer.
// Just after defining the featurelayer >
dojo.connect(featureLayer, "onUpdateEnd", function() {
var zoomExtent = esri.graphicsExtent(featureLayer.graphics);
});     //  now the zoom won't happen until map is updated
RoseZhou
But this event keeps firing... If you add an alert in this event handler, you will know what I mean. How to fix this problem?
Thanks
HunterWei
Thanks
I met the same issue, but finally I figured it out with a turnaournd approach by using a featurelayer query, see below code
featureLayer.setDefinitionExpression("COUNTY='" + value + "'");
var query = new esri.tasks.Query();
query.where = "1=1";
query.outSpatialReference = map.spatialReference;
featureLayer.queryFeatures(query, function (featureSet) {
    var data = [];
    if (featureSet && featureSet.features && featureSet.features.length > 0) {
        data = featureSet.features;
    var zoomExtent = esri.graphicsExtent(data);
