Zoom Slider position
3681
09-13-2013 11:45 PM
ChiranjeeviGK
Hi
can we move the zoom slider to different location like bottom right corner?
can you help me how?
GregKnight
Once you've defined the slider style in your js, you can take care of positioning and styling through css.
The css class names for the large and small sliders are .esriLargeSlider and .esriSimpleSlider respectively.
Here's a sample:
https://developers.arcgis.com/en/javascript/jssamples/mapconfig_pos_size.html
Hope this helps,
Greg
GaneshSolai_Sambandam
Yes, you can position zoom slider
Try the syntax below
var map = new esri.Map("map", {
          showAttribution: false,
          sliderPosition: "top-right",
          sliderStyle: "large"
if you put it in the bottom of your webmap page, then, try "bottom-right" or "bottom-left"
Also, you can change the sliderStyle: from "large" to "small"
GregKnight
Here's a sample:
Hope this helps,
Greg
