Zoom Slider Increment Buttons Won't Hide
1977
09-01-2011 04:03 AM
RickScott
Hi folks,
I have map.hideZoomSlider() and:
#map_zoom_slider{
visibility: hidden !important;
But I'm still getting the zoom slider increment and decrement buttons.
Any additional suggestions would be greatly appreciated.
Rick Scott
StephenLead
Honored Contributor
Hi Rick,
I'm not positive I understand your problem, but if you're trying to hide the Zoom In and Zoom Out arrows at the top and bottom of the Zoom Slider, you could use:
.dijitSliderIncrementIconV, .dijitSliderDecrementIconV {
    display: none;
Steve
RickScott
Hi Rick,
    display: none;
Steve
Awesome!  Thanks, Steve, that did it!
Trying to find the correct combination of id/class and CSS attribute is so frustratingly hard.
Thanks again!
Rick
StephenLead
Honored Contributor
Rick,
Have you tried FireFox with the Firebug plugin? The HTML inspector makes this a bit easier, as it will show you which CSS rules are being used for a particular element.
Steve
RedLong
Hi Rick,
    display: none;
Steve
You're the man :cool:
