Zoom Scale bar - show zoom level  Label on change of scale in zoom slider bar
1409
04-13-2011 09:19 AM
nidhiarora
Hi
I want the zoom slider bar to display the scale when it is moved up or down . Is there any event which can capture this?
i looked into API , i am able to follow the sample available to show labels in zoom slider bar . Is it feasible to show label in zoom slider bar when user has zoomed to that level , instead of showing labels for all the levels.
Something like zoom slider bar which is available in flex
regards,
Nidhi Arora
VipulJajal
I achieved this as follows.
On the form, I had the dedicated input box labelled as "Approximate Scale:"
First register the event "onZoomEnd" on the map as follows:
  dojo.connect(map, "onZoomEnd", showMapScale);
The JavaScript function "showMapScale" is shown below:
function showMapScale(extent, zoomFactor, anchor, level) {
var scale = tiledMapService.tileInfo.lods[level].scale;
dojo.byId("scaleText").value = "1:" + scale;
Here tiledMapService is the ArcGISTiledMapServiceLayer displaying the base map.
tiledMapService = new esri.layers.ArcGISTiledMapServiceLayer(primaryMapServiceURL);
This way, you can display the scale.
Not exactly the way you want but hope this helps.
