zoom into the map
3348
02-21-2016 10:07 PM
ADITIROY
Hello ,
I am getting a problem in plotting the graphics and zoom into the feature on the map. Here below is my code. Please help. The data is getting populated into the grid and after that it is not zooming into the map.
define([
        "dojo/_base/declare",
        "dijit/_WidgetBase",
        "dijit/_TemplatedMixin",
        'dijit/_WidgetsInTemplateMixin',
        'dojo/_base/lang',
        "esri/tasks/query",
        "dojo/text!/Widgets/SearchButton/SearchButton.html",
        "xstyle/css!/Widgets/SearchButton/css/StyleSheet.css",
        "esri/Color",
        "esri/tasks/locator",
        "esri/InfoTemplate",
         "esri/symbols/Font",
         "esri/symbols/TextSymbol",
          "dojo/_base/array",
          "dojo/number",
          "dojo/parser",
           "esri/tasks/FindTask",
        "esri/tasks/FindParameters",
        "dojo/_base/connect",
        "dojox/grid/DataGrid",
        "dojo/data/ItemFileReadStore",
            "esri/graphic",
        "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleFillSymbol",
        "esri/symbols/SimpleMarkerSymbol",
        "dojo/on",
        "dijit/form/Button",
        "esri/geometry/Point",
        'require',
        "dojox/widget/Standby",
        "dojo/_base/window",
        "dojo/window",
        "dojo/dom",
        "dojo/dom-attr",
        "dijit/registry",
        "dijit/form/NumberTextBox",
        "dijit/Dialog",
        "esri/tasks/geometry",
        "dojo/domReady!"
], function (declare, _WidgetBase, _TemplatedMixin, _WidgetsInTemplateMixin, lang, query, template, widgetCss,
Color, locator, InfoTemplate, Font, TextSymbol, array, number, parser, FindTask, FindParameters, connect, DataGrid, ItemFileReadStore,
         Graphic, SimpleLineSymbol, SimpleFillSymbol, SimpleMarkerSymbol, on, Button, Point, require,
  Standby, win, window, dom, domAttr, registry, NumberTextBox, Dialog,
       Geometry) {
    var imageUrl = require.toUrl("./images");
    var searchDialogbox;
    var center, zoom;
    var grid, store;
    return declare([_WidgetBase, _TemplatedMixin, _WidgetsInTemplateMixin], {
        // widgetsInTemplate: true,
        templateString: template,
        map: null,
        Map: null,
        imageUrl: imageUrl,
        findParams: null,
        searchDialogbox: null,
        findtask: null,
        searchText: null,
        spatialReference: null,
        featureUrl:null,
        map: this.map,
        //doFind:null,
        postCreate: function () {
        findtask1: function () {
            this.findtask = new FindTask("http://");
            this.findParams = new FindParameters();
            this.findParams.returnGeometry = true;
            this.findParams.layerIds = [0];
            this.findParams.searchFields = ["OBJECTID","FEEDER_NAME"];
            this.findParams.outSpatialReference = this.map.spatialReference;
            console.log("find sr: ", this.findParams.outSpatialReference);
        doFind: function () {
            //Set the search text to the value in the box
            this.findParams.searchText = this.ownerName.value;
            this.findtask.execute(this.findParams, lang.hitch(this, this.showResults));
        showResults: function (results) {
            console.log(results);
            this.map.graphics.clear();
            var symbol = new SimpleFillSymbol(
              SimpleFillSymbol.STYLE_SOLID,
              new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([98, 194, 204]), 2),
              new Color([98, 194, 204, 0.5])
            //create array of attributes
            var items = array.map(results, function (result) {
                var graphic = result.feature;
                console.log(graphic);
                graphic.setSymbol(symbol);
                this.map.graphics.add(graphic);
                return result.feature.attributes;
            console.log("alertqb");
            var data = {
                identifier: "OBJECTID", //This field needs to have unique values
                label: "OBJECTID", //Name field for display. Not pertinent to a grid but may be used elsewhere.
                items: items
            //Create data store and bind to grid.
            store = new ItemFileReadStore({
                data: data
            var grid = registry.byId("grid");
            grid.setStore(store);
           grid.on("rowclick", lang.hitch(this, this.onRowClickHandler));
            console.log("rowclick");
            //Zoom back to the initial map extent
            this.map.centerAndZoom(center, zoom);
        onRowClickHandler: function (evt) {
            console.log("1");
            var clicked = evt.grid.getItem(evt.rowIndex).OBJECTID;
            console.log('clicked');
            var selected = array.filter(this.map.graphics.graphics, function (graphic) {
                return ((graphic.attributes) && graphic.attributes.OBJECTID === clicked);
            console.log('clicked20');
            if (selected.length) {
                this.map.setExtent(selected[0].geometry.getExtent(), true);
                console.log('clicked25');
Tags (3)
syangL
ADITI,
  It seems that you didn't assign a value to  center and the zoom.
more information about centerAndZoom :Map | API Reference | ArcGIS API for JavaScript
In your cases ,I prefer to use  centerAt:Map | API Reference | ArcGIS API for JavaScript  or setextent:  Map | API Reference | ArcGIS API for JavaScript
This is  a piece of code I had use in the same situation。
// graphic might be your result.feature.
function centerGraphic(graphic){
  switch (graphic.geometry.type) {
         case "point":
           map.centerAndZoom(graphic.geometry,map.getLevel()+1);
           break;
         case "polyline":
          var line = graphic.geometry.getExtent();
          map.setExtent(line.expand(1.6));
           break;
         case "polygon":
          var ext = graphic.geometry.getExtent();
          map.setExtent(ext.expand(1.6));
           break;
Good day!
ADITIROY
Thank You so much Moya y
ADITIROY
Dear moya Y,
I integrated the code but it is still not working.
define([
        'dojo/_base/lang',
        "esri/tasks/query",
        "esri/Color",
          "dojo/_base/array",
          "dojo/number",
          "dojo/parser",
            "esri/graphic",
        "dojo/on",
        'require',
        "dojo/window",
        "dojo/dom",
        "dojo/dom-attr",
        "dijit/registry",
        "dijit/Dialog",
        "dojo/domReady!"
       Geometry) {
    var center, zoom;
    var grid, store;
        map: null,
        Map: null,
        imageUrl: imageUrl,
        findParams: null,
        findtask: null,
        searchText: null,
        featureUrl:null,
        map: this.map,
        //doFind:null,
            dojo.query("#lnkSearchByButton").connect("onclick", lang.hitch(this, this.Searchbutton));
            dojo.query("#Searchbtn").connect("onclick", lang.hitch(this, this.doFind));
            searchDialogbox = new Dialog({
                title: 'Search On ButtonClick',
                loadingMessage: 'Loading...',
            }, 'divSearchbutton');
            this.onRowClickHandler();
            var data = {
                items: items
                data: data
           grid.on("rowclick", lang.hitch(this, this.centergraphic));
        centergraphic: function (graphic)
            switch (this.graphic.geometry.type) {
                case "point":
                    this.map.centerAndZoom(this.graphic.geometry, this.map.getLevel() + 1);
                    break;
                case "polyline":
                    var line = this.graphic.geometry.getExtent();
                    this.map.setExtent(line.expand(1.6));
                    break;
                case "polygon":
                    var ext = this.graphic.geometry.getExtent();
                    this.map.setExtent(ext.expand(1.6));
                    break;
        //Open the dialog box
        Searchbutton: function () {
            searchDialogbox.show();
            this.findtask1();
RobertScheitlin__GISP
Aditi,
   So are you passing in the "center" and "zoom" var values when you initialize this widget?
Do you get into your rowclick event handler?
ADITIROY
Robert,
Thank you. Yes, I getting into the rowclick event handler and i have not passed any values for zoom and center.The result is getting plotted into the grid but is not zooming into the feature in the map.
Aditi
