Zoom Button are not working after update
2437
04-16-2024 12:49 AM
infeo
We are using arcgis js sdk within our angular (17) application. We updated from @ArcGIS/[email protected] to @ArcGIS/[email protected] we realized that the zoom buttons are (most of the time) not working. Meaning by clicking on the "+" button the zoom level does not change. Using the mouse wheel to zoom works fine.
When downgrading to the older version the buttons work like intended.
I also created an example: https://stackblitz.com/edit/stackblitz-starters-tlrh2e?file=package.json
To downgrade arcgis run:
npm uninstall @ArcGIS/core
npm install @ArcGIS/[email protected]
Many thanks in advanced
Edit: Duplicate of https://community.esri.com/t5/arcgis-javascript-maps-sdk-questions/zoom-buttons-don-t-work-in-angula...  => Workaround see: https://github.com/Esri/jsapi-resources/tree/main/esm-samples/jsapi-angular-cli#known-issues
infeo
I figured out that the problem is a bug in Angular / zone.js. Updating zone.js to 0.14.5 fixed the issue. See this reply: https://community.esri.com/t5/arcgis-javascript-maps-sdk-questions/zoom-buttons-don-t-work-in-angula...
AllenHuang
Hi
I recently switched over to 4.30 from 4.24 and the same thing happened to me too.
I develop my map with CDN. The zoom widget would work as a stand-alone map. But when I build my map into Drupal on the fly with Angular, the zoom control and home widget stopped working altogether.
Is this similar to what's been happening to you?
infeo
AllenHuang
Hi
I also think the bug in the zone.js library is the cause of the issue. I found out that the Angular version that I'm running my maps on runs zone.js v0.11.4. But I have no way of testing it at the moment.
