Z Value difference in Web Scene
1215
01-02-2024 12:45 AM
jauhari_mani
I've created a Web Scene for an indoors on ArcGIS Online. I'm attempting to insert a graphic at the clicked map point within the scene to obtain the z-value. I'm deriving this value from the z-value configured in the level layer of the Web Scene. However, there is a disparity in the z-values. When I click on the map, the event returns a value of 219, while the level layer specifies a value of 6. What might be causing this inconsistency?
ArnoFiva
Thanks for your question! I believe the Indoors data model works with relative-to-ground z-values. So your floor is configured to be 6 meters above ground, while in a web scene with elevation layer, it is actually placed 219 meters above sea level. This could explain the discrepancy, but this is just guessing without being able to access the actual data.
