heads up: esri-loader is deprecated in 4.29 of the JS API
2042
01-17-2024 05:01 AM
AValenski
Wanted to give as advanced notice as possible as Esri updated their Next JS API GitHub with the 4.29 change notices yesterday.
Per the change log "The esri-loader library is deprecated at version 4.29. Use components or the @ArcGIS/core ES modules instead."
Additionally, there're a host of other breaking changes in this release. I've catalogued them below, but the full list of recent deprecations and breaking changes are available via the above links:
  • At version 4.29, only WebGL2-enabled browsers are supported for both 2D and 3D. See the System Requirements for more information. (here's the support matrix)
  • For local builds, using Webpack versions prior to 5.84.0 is not recommended for 4.29. This is related to bug fixes in Webpack.
  • Removal of FetchPopupFeaturesResult members in the Popup class. The FetchPopupFeaturesResult type definition in the Popup class had the following properties removed from the API at this release: FetchPopupFeaturesResult.clientOnlyGraphicsFetchPopupFeaturesResult.promisesPerLayerViewFetchPopupFeaturesPromisesPerLayerView
  • BasemapLayerList.multipleSelectionEnabled deprecated since 4.29. Use selectionMode instead.
  • BasemapLayerList.editingEnabled deprecated since 4.29. Use dragEnabled, selectionMode, and visibleElements.editButton instead.
  • LayerList.multipleSelectionEnabled deprecated since 4.29. Use selectionMode instead.
  • LayerList.selectionEnabled deprecated since 4.29. Use dragEnabled and selectionMode instead.
  • Popup.spinnerEnabled deprecated since 4.29. Use PopupVisibleElements.spinner instead.
  • TableList.multipleSelectionEnabled deprecated since 4.29. Use selectionMode instead.
  • TableList.selectionEnabled deprecated since 4.29. Use dragEnabled and selectionMode instead.
  • Popup.collapseEnabled deprecated since 4.29. Use PopupVisibleElements.collapseButton instead.
4.29 is set for release in February of 2024.
