Yet another CORS issue
7929
6
03-25-2015 05:47 AM
AdrianMarsden
Honored Contributor
I thought I had seen the last of these.  However, I am trying to retrieve the EXIF metadata of attached images using this code jseidelin/exif-js · GitHub  - it works when I run the example page and load in the full URL of the images returned via a " featureLayer.queryAttachmentInfos" command.
However, the AGS server being a different domain to my site hits CORS issues - which I thought I had sorted by changes to web.config and adding the server name in with a "esri.config.defaults.io.corsEnabledServers.push"
However, when I try to retrieve the data using a simple function
        for (index = 0; index < attachmentPath.length; ++index) {
            var image = new Image();
            image.src = attachmentPath[index];
            image.onload = function () { // always fires the event.
                EXIF.getData(this, function () {
                    console.debug(this)
                    var make = EXIF.getTag(this, "Make"),
                        model = EXIF.getTag(this, "Model");
                    alert("I was taken by a " + make + " " + model);
           ....do stuff with the info returned
I get
XMLHttpRequest cannot load http://<<server name>>/arcgis/rest/services/test/emap2/MapServer/22/2009/attachments/8. Request header field If-Modified-Since is not allowed by Access-Control-Allow-Headers.
All other requests to resources using the server name seem fine.
I'm stumped.  All I want to do is to know which way up to display the attachments!
JeffJacobson
Are you sure that CORS is enabled on your ArcGIS Server? (Older versions of ArcGIS Server did not have CORS enabled by default.)
AdrianMarsden
Honored Contributor
I'm using 10.2.2 and I believe it is all enabled - the same results occur when I strip the code out and have no AGS component.
OK - also tested it in IE - it gave me an alert about loading stuff outside of control, but loaded OK (failed elsewhere, but that my problem)
Firefox gave
Cross-Origin Request Blocked: The Same Origin Policy disallows reading the remote resource at http://<<server name>>/arcgis/rest/services/test/emap2/MapServer/22/2006/attachments/6/index.html. This can be fixed by moving the resource to the same domain or enabling CORS.
So, assuming I haven't got CORS enabled - how do I?  I have read about this for several years now, and yet found a simple answer.
I have
<customHeaders>
        <add name="Access-Control-Allow-Origin" value="*"/>
</customHeaders>
In my webconfig.
Cheers
ACM
AdrianMarsden
Honored Contributor
Also, I think I am confused over what server needs what, or rather what part of the same server needs what.
I have my AGS component.  That runs on the default website of  IIS .  It has a web.config and settings in IIS.
Then there is my application.  On the same server, but a different site in IIS.  That also has its settings and (potentially) a web.config.
I have tried all sorts of combinations of edits to web.config and either the page fails totally with a http 500, it fails with
The 'Access-Control-Allow-Origin' header contains multiple values 'http://applicationservername, *', but only one is allowed.
Or the other error above.
I am really bashing head against wall here.
GaryBushek
Having the same issue. Were you able to resolve this?  I set the response header to enable Cors on the server and added esriConfig.defaults.io.corsEnabledServers to the code but no luck.
Thanks
AdrianMarsden
Honored Contributor
Things are a lot better now.  I stripped things right back, removed any CORS related stuff from any web.config files (I had a few at different levels of the site) and ensured that the settings were only specifed in one location - I can't pinpoint what I did, as it was a case of trying loads of stuff at random.  I still don't know which part of the server was rejecting it, the calling page or the site being called.
AndrewRay1
I just ran into a similar issue with the Access-Control-Allow-Headers not including the "pragma" header, for some reason a client applicaiton was adding that header to the request and then when my server did not echo it back as an acceptable header in the response header "Access-Control-Allow-Headers" the browser (google chrome) would fail the preflight and not perform the "get" operation.
does the web adapter or server handle the response for CORS requests or if this something i need to do inside my web.config.
note: i am running 10.3.1 portal on windows + web adapter in IIS
