WMTS Time-enabled layer
1283
05-26-2014 12:19 PM
DavidElies
Hi All,
I want to access a time-enabled WMTS service and request several images based on time (the latest weather radar images).  I can't find anywhere in the WMTSLayer class which lets me specify time.  Does anybody know if this is possible?
Thanks!
DavidElies
Is it possible to just override whatever internal method the WMTSLayer uses to make the actual request to the WMTS endpoint?  Then I could add a property and function to change the time. (I'd probably want to cache the frames, too).  Is there an un-minified, un-obfuscated version of the library I can look at to extend/edit the WMTSLayer "class"?
Thanks!
