WMTS and MapImage layer mismatch
1558
10-04-2022 02:47 AM
Nikarayanpouya
Hi!!
I use two layers MapImageLayer and WMTSLayer in my project.
I use Portable Base Map for WMTS layer
But the display of the WMTS layer is different from the MapImage layer and they do not match.While when
I use OSM online map it works without any problem.😑
Use PortableBaseMap:
Use BaseMap  Defulat OSM:
PBS XML:
Capabilities xsi:schemaLocation="http://www.opengis.net/wmts/1.0 http://schemas.opengis.net/wmts/1.0/wmtsGetCapabilities_response.xsd" version="1.0.0">
<!-- Service Identification -->
<ows:ServiceIdentification>
<ows:Title>OpenStreetMap</ows:Title>
<ows:ServiceType>OGC WMTS</ows:ServiceType>
<ows:ServiceTypeVersion>1.0.0</ows:ServiceTypeVersion>
</ows:ServiceIdentification>
<ows:ServiceProvider>
<ows:ProviderName>Portable Basemap Server</ows:ProviderName>
<ows:ProviderSite xlink:href="https://geopbs.codeplex.com/"/>
<ows:ServiceContact>
<ows:IndividualName>diligentpig</ows:IndividualName>
</ows:ServiceContact>
</ows:ServiceProvider>
<!-- Operations Metadata -->
<ows:OperationsMetadata>
<ows:Operation name="GetCapabilities">
<ows:DCP>
<ows:HTTP>
<ows:Get xlink:href="http://192.168.0.103:7080/PBS/rest/services/OpenStreetMap/MapServer/WMTS/1.0.0/WMTSCapabilities.xml">
<ows:Constraint name="GetEncoding">
<ows:AllowedValues>
<ows:Value>RESTful</ows:Value>
</ows:AllowedValues>
</ows:Constraint>
</ows:Get>
<ows:Get xlink:href="http://192.168.0.103:7080/PBS/rest/services/OpenStreetMap/MapServer/WMTS?">
<ows:AllowedValues>
<ows:Value>KVP</ows:Value>
</ows:Constraint>
</ows:Get>
</ows:HTTP>
</ows:DCP>
</ows:Operation>
<ows:Operation name="GetTile">
<ows:DCP>
<ows:HTTP>
<ows:Get xlink:href="http://192.168.0.103:7080/PBS/rest/services/OpenStreetMap/MapServer/WMTS/tile/1.0.0/">
<ows:AllowedValues>
</ows:Constraint>
</ows:Get>
<ows:AllowedValues>
</ows:Constraint>
</ows:Get>
</ows:HTTP>
</ows:DCP>
</ows:Operation>
</ows:OperationsMetadata>
<Contents>
<!--Layer-->
<Layer>
<ows:Identifier>OpenStreetMap</ows:Identifier>
<ows:BoundingBox crs="urn:ogc:def:crs:EPSG::3857">
<ows:LowerCorner>-20037508.342787 -20037508.342787</ows:LowerCorner>
<ows:UpperCorner>20037508.342787 20037508.342787</ows:UpperCorner>
</ows:BoundingBox>
<ows:WGS84BoundingBox crs="urn:ogc:def:crs:OGC:2:84">
<ows:LowerCorner>-179.99999999998 -85.0511287798049</ows:LowerCorner>
<ows:UpperCorner>179.99999999998 85.0511287798049</ows:UpperCorner>
</ows:WGS84BoundingBox>
<Style isDefault="true">
<ows:Title>Default Style</ows:Title>
<ows:Identifier>default</ows:Identifier>
</Style>
<Format>image/png</Format>
<TileMatrixSetLink>
<TileMatrixSet>default028mm</TileMatrixSet>
</TileMatrixSetLink>
<TileMatrixSetLink>
<TileMatrixSet>nativeTileMatrixSet</TileMatrixSet>
<TileMatrixSetLink>
<TileMatrixSet>GoogleMapsCompatible</TileMatrixSet>
<ResourceURL format="image/png" resourceType="tile" template="http://192.168.0.103:7080/PBS/rest/services/OpenStreetMap/MapServer/WMTS/tile/1.0.0/OpenStreetMap/{Style}/{TileMatrixSet}/{TileMatrix}/{TileRow}/{TileCol}.png"/>
</Layer>
<!--TileMatrixSet-->
<TileMatrixSet>
<ows:Title>Default TileMatrix using 0.28mm</ows:Title>
<ows:Abstract>
The tile matrix set that has scale values calculated based on the dpi defined by OGC specification (dpi assumes 0.28mm as the physical distance of a pixel).
</ows:Abstract>
<ows:Identifier>default028mm</ows:Identifier>
<ows:SupportedCRS>urn:ogc:def:crs:EPSG::3857</ows:SupportedCRS>
<TileMatrix>
<ows:Identifier>0</ows:Identifier>
<ScaleDenominator>559081145.86404371</ScaleDenominator>
<TopLeftCorner>-20037508.342787 20037508.342787</TopLeftCorner>
<TileWidth>256</TileWidth>
<TileHeight>256</TileHeight>
<MatrixWidth>2</MatrixWidth>
<MatrixHeight>2</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ows:Identifier>1</ows:Identifier>
<ScaleDenominator>279540572.93202186</ScaleDenominator>
<MatrixWidth>3</MatrixWidth>
<MatrixHeight>3</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ows:Identifier>2</ows:Identifier>
<ScaleDenominator>139770286.46601093</ScaleDenominator>
<MatrixWidth>5</MatrixWidth>
<MatrixHeight>5</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ows:Identifier>3</ows:Identifier>
<ScaleDenominator>69885143.233005464</ScaleDenominator>
<MatrixWidth>9</MatrixWidth>
<MatrixHeight>9</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ows:Identifier>4</ows:Identifier>
<ScaleDenominator>34942571.616502732</ScaleDenominator>
<MatrixWidth>17</MatrixWidth>
<MatrixHeight>17</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ows:Identifier>5</ows:Identifier>
<ScaleDenominator>17471285.808251366</ScaleDenominator>
<MatrixWidth>33</MatrixWidth>
<MatrixHeight>33</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ows:Identifier>6</ows:Identifier>
<ScaleDenominator>8735642.904125683</ScaleDenominator>
<MatrixWidth>65</MatrixWidth>
<MatrixHeight>65</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ows:Identifier>7</ows:Identifier>
<ScaleDenominator>4367821.4520628415</ScaleDenominator>
<MatrixWidth>129</MatrixWidth>
<MatrixHeight>129</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ows:Identifier>8</ows:Identifier>
<ScaleDenominator>2183910.7260314208</ScaleDenominator>
<MatrixWidth>257</MatrixWidth>
<MatrixHeight>257</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ows:Identifier>9</ows:Identifier>
<ScaleDenominator>1091955.3630157104</ScaleDenominator>
<MatrixWidth>513</MatrixWidth>
<MatrixHeight>513</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ows:Identifier>10</ows:Identifier>
<ScaleDenominator>545977.68150785519</ScaleDenominator>
<MatrixWidth>1025</MatrixWidth>
<MatrixHeight>1025</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ows:Identifier>11</ows:Identifier>
<ScaleDenominator>272988.84075392759</ScaleDenominator>
<MatrixWidth>2049</MatrixWidth>
<MatrixHeight>2049</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ows:Identifier>12</ows:Identifier>
<ScaleDenominator>136494.4203769638</ScaleDenominator>
<MatrixWidth>4097</MatrixWidth>
<MatrixHeight>4097</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ows:Identifier>13</ows:Identifier>
<ScaleDenominator>68247.2101884819</ScaleDenominator>
<MatrixWidth>8193</MatrixWidth>
<MatrixHeight>8193</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ows:Identifier>14</ows:Identifier>
<ScaleDenominator>34123.605094240949</ScaleDenominator>
<MatrixWidth>16385</MatrixWidth>
<MatrixHeight>16385</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ows:Identifier>15</ows:Identifier>
<ScaleDenominator>17061.802547120475</ScaleDenominator>
<MatrixWidth>32769</MatrixWidth>
<MatrixHeight>32769</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ows:Identifier>16</ows:Identifier>
<ScaleDenominator>8530.9012735602373</ScaleDenominator>
<MatrixWidth>65537</MatrixWidth>
<MatrixHeight>65537</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ows:Identifier>17</ows:Identifier>
<ScaleDenominator>4265.4506367801187</ScaleDenominator>
<MatrixWidth>131073</MatrixWidth>
<MatrixHeight>131073</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ows:Identifier>18</ows:Identifier>
<ScaleDenominator>2132.7253183900593</ScaleDenominator>
<MatrixWidth>262145</MatrixWidth>
<MatrixHeight>262145</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ows:Identifier>19</ows:Identifier>
<ScaleDenominator>1066.3626591950297</ScaleDenominator>
<MatrixWidth>524289</MatrixWidth>
<MatrixHeight>524289</MatrixHeight>
</TileMatrix>
</TileMatrixSet>
<TileMatrixSet>
<ows:Title>Native TiledMapService TileMatrixSet</ows:Title>
<ows:Abstract>
the tile matrix set that has scale values calculated based on the dpi defined by ArcGIS Server tiled map service. The current tile dpi is 96
</ows:Abstract>
<ows:Identifier>nativeTileMatrixSet</ows:Identifier>
<TileMatrix>
<ScaleDenominator>591657527.591555</ScaleDenominator>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>295828763.7957775</ScaleDenominator>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>147914381.89788875</ScaleDenominator>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>73957190.948944375</ScaleDenominator>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>36978595.474472187</ScaleDenominator>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>18489297.737236094</ScaleDenominator>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>9244648.8686180469</ScaleDenominator>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>4622324.4343090234</ScaleDenominator>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>2311162.2171545117</ScaleDenominator>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>1155581.1085772559</ScaleDenominator>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>577790.55428862793</ScaleDenominator>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>288895.27714431396</ScaleDenominator>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>144447.63857215698</ScaleDenominator>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>72223.819286078491</ScaleDenominator>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>36111.909643039246</ScaleDenominator>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>18055.954821519623</ScaleDenominator>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>9027.9774107598114</ScaleDenominator>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>4513.9887053799057</ScaleDenominator>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>2256.9943526899528</ScaleDenominator>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>1128.4971763449764</ScaleDenominator>
</TileMatrix>
</TileMatrixSet>
<TileMatrixSet>
<ows:Title>GoogleMapsCompatible</ows:Title>
<ows:Abstract>
the wellknown 'GoogleMapsCompatible' tile matrix set defined by OGC WMTS specification
</ows:Abstract>
<ows:Identifier>GoogleMapsCompatible</ows:Identifier>
<ows:SupportedCRS>urn:ogc:def:crs:EPSG:6.18:3:3857</ows:SupportedCRS>
<WellKnownScaleSet>urn:ogc:def:wkss:OGC:1.0:GoogleMapsCompatible</WellKnownScaleSet>
<TileMatrix>
<ScaleDenominator>559082264.02871776</ScaleDenominator>
<TopLeftCorner>-20037508.34278925 20037508.34278925</TopLeftCorner>
<MatrixWidth>1</MatrixWidth>
<MatrixHeight>1</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>279541132.01435888</ScaleDenominator>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>139770566.00717944</ScaleDenominator>
<MatrixWidth>4</MatrixWidth>
<MatrixHeight>4</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>69885283.00358972</ScaleDenominator>
<MatrixWidth>8</MatrixWidth>
<MatrixHeight>8</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>34942641.50179486</ScaleDenominator>
<MatrixWidth>16</MatrixWidth>
<MatrixHeight>16</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>17471320.75089743</ScaleDenominator>
<MatrixWidth>32</MatrixWidth>
<MatrixHeight>32</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>8735660.3754487149</ScaleDenominator>
<MatrixWidth>64</MatrixWidth>
<MatrixHeight>64</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>4367830.1877243575</ScaleDenominator>
<MatrixWidth>128</MatrixWidth>
<MatrixHeight>128</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>2183915.0938621787</ScaleDenominator>
<MatrixWidth>256</MatrixWidth>
<MatrixHeight>256</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>1091957.5469310894</ScaleDenominator>
<MatrixWidth>512</MatrixWidth>
<MatrixHeight>512</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>545978.77346554468</ScaleDenominator>
<MatrixWidth>1024</MatrixWidth>
<MatrixHeight>1024</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>272989.38673277234</ScaleDenominator>
<MatrixWidth>2048</MatrixWidth>
<MatrixHeight>2048</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>136494.69336638617</ScaleDenominator>
<MatrixWidth>4096</MatrixWidth>
<MatrixHeight>4096</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>68247.346683193085</ScaleDenominator>
<MatrixWidth>8192</MatrixWidth>
<MatrixHeight>8192</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>34123.673341596543</ScaleDenominator>
<MatrixWidth>16384</MatrixWidth>
<MatrixHeight>16384</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>17061.836670798271</ScaleDenominator>
<MatrixWidth>32768</MatrixWidth>
<MatrixHeight>32768</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>8530.9183353991357</ScaleDenominator>
<MatrixWidth>65536</MatrixWidth>
<MatrixHeight>65536</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>4265.4591676995678</ScaleDenominator>
<MatrixWidth>131072</MatrixWidth>
<MatrixHeight>131072</MatrixHeight>
</TileMatrix>
<TileMatrix>
<ScaleDenominator>2132.7295838497839</ScaleDenominator>
<MatrixWidth>262144</MatrixWidth>
<MatrixHeight>262144</MatrixHeight>
</TileMatrix>
</TileMatrixSet>
</Contents>
<ServiceMetadataURL xlink:href="http://192.168.0.103:7080/PBS/rest/services/OpenStreetMap/MapServer/WMTS/1.0.0/WMTSCapabilities.xml"/>
</Capabilities>
ZhouJachin
Hi, Could you show me the code how to build a wmtsLayer? I have a xml file like yours, but it can't work in arcgis4
