WMS Layer from external server (via Custom WMS / WMS resource info)
4056
11-11-2015 04:50 AM
FriedrichStriewski1
I try to add a WMS layer to an ESRI basemap, following the templates of Custom WMS or WMS resource info​. As result I get the basemap displayed properly but the WMS layer is missing. Honestly I have no idea what I am doing wrong.
GetCapabilites:
http://nibis.lbeg.de/net3/public/ogc.ashx?PkgId=24&Version=1.1.1&Service=WMS&Request=GetCapabilities
My request is:
http://nibis.lbeg.de/net3/public/ogc.ashx?PkgId=22&Version=1.1.1&Service=WMS&Request&Service=WMS&Req...
Translated into the "WMS Resource Info" template, I highlighted the relevant parts:
  <script>
    var map;
    require([
      'esri/map', 'esri/layers/WMSLayer', 'esri/layers/WMSLayerInfo', 'esri/geometry/Extent',
      'dojo/_base/array', 'dojo/dom', 'dojo/dom-construct', 'dojo/parser',
      'dijit/layout/BorderContainer', 'dijit/layout/ContentPane', 'dojo/domReady!'
    ], function(Map, WMSLayer, WMSLayerInfo, Extent, array, dom, domConst, parser) {
      parser.parse();
      map = new Map('map', {
        basemap: 'satellite',
        center: [10.56, 51.738],
        zoom: 12
      var layer1 = new WMSLayerInfo({
        title: 'Geo'
      var layer2 = new WMSLayerInfo({
        title: 'Cities'
      var resourceInfo = {
        version: "1.1.1",
        format: "png",
        extent: new Extent(728861,6661184,1307070,7157726, {
          wkid: 3857
        layerInfos: [layer1, layer2]
      var wmsLayer = new WMSLayer('http://nibis.lbeg.de/net3/public/ogc.ashx?', {
        resourceInfo: resourceInfo,
        visibleLayers: ['L23', '2']
      map.addLayers([wmsLayer]);
      var details = dom.byId('details');
      domConst.place('<b>Layers</b>:', details);
      var ul = domConst.create('ul', null, details);
      array.forEach(wmsLayer.layerInfos, function(layerInfo) {
        domConst.create('li', { innerHTML: layerInfo.title }, ul);
      domConst.place('<b>WMS Version</b>:' + wmsLayer.version + '<br />', details);
  </script>
Same with "Custom Layer - WMS":
    <script>
      dojo.require("esri.map");
      var map;
      dojo.ready(function() {
        dojo.declare("my.GeoLayer", esri.layers.DynamicMapServiceLayer, {
          constructor: function() {
            this.initialExtent = this.fullExtent =    new esri.geometry.Extent({"xmin":728861,"ymin":6661184,"xmax":1307070,"ymax":7157726,"spatialReference":{"wkid":102100}});
            this.spatialReference = new esri.SpatialReference({wkid:102100});
            this.loaded = true;
            this.onLoad(this);
          getImageUrl: function(extent, width, height, callback) {
            var params = {
              request:"GetMap",
              transparent:true,
              format:"image/png",
              bgcolor:"ffffff",
              version:"1.1.1",
              layers:"L23",
              styles: "default,default",
              exceptions: "application/vnd.ogc.se_xml",
              //changing values
              bbox:extent.xmin + "," + extent.ymin + "," + extent.xmax + "," + extent.ymax,
              srs: "EPSG:" + extent.spatialReference.wkid,
              width: width,
              height: height
            callback("http://nibis.lbeg.de/net3/public/ogc.ashx?" + dojo.objectToQuery(params));
      function init() {
        map = new esri.Map("map", {
          basemap: "satellite",
          zoom: 10
        map.addLayer(new my.GeoLayer());
      dojo.ready(init);
    </script>
JoshHevenor
Just first thoughts...Your declares look a little scant in your definition of my.GeoLayer. I would try to write this using as much AMD as you can.   Also, you're my.GeoLayer is defined with  DynamicMapServiceLayer and not a wmslayer.
