Widget for Floor Picker
4204
12
08-01-2017 08:23 AM
deleted-user-HEuiQnZBaYD3
Hi
Anyone working on Widget for floor picker
RickeyFight
Are you thinking for WAB? Also 3D or 2D?
Currently for 2D
RickeyFight
I have one that I use. Its more of a definition query/filter widget. You will have to do a little coding to get it to work for your situation.
GitHub - daFiter/localLayer_filter: Esri Web AppBuilder filter Widget
Thanks for your suggestion, i have tried this widget it is not able work if i give ok or cancle it is not able to close.
If you have time can you show me how to work with this, i am working with WAB 2.4
RickeyFight
This is what I have it configured to look like.
I just added my current widget from WAB 2.2 and it works for me in WAB 2.5
If i used search tool to find a person in a different level that the displayed, will it automatically change the identified person level?
RickeyFight
You are looking for a widget for WAB that does what this app does?
http://tryitlive.arcgis.com/CampusPlaceLocator/index.html
I have not gotten around to adding this functionality but some day I hope that it gets added to WAB.
Your Right, I am looking similar to this. Similar tool is available for Silverlight not for WAB
