Widget: BasemapGallery dropdown question
8880
24
12-20-2011 06:31 AM
JanBenson
I just posted this, but can't find it so I will try again.
I am trying to duplicate the widget BasemapGallery- dropdown (http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm) button.  I want this particular one because I can customize the dropdown window and I want a simple dropdown button.  The example uses all Bing items.  I want to use the basemaps Ocean_Basemap, NatGeo_World_Map, and I3_Imagery_Prime_World_2D .  My confusion is in the type and id.  The example code shows the following:
      function createBasemapGallery(){
        //Manually create a list of basemaps to display
        var basemaps = [];
        var basemapRoad = new esri.dijit.Basemap({
          layers: [new esri.dijit.BasemapLayer({
            type: "BingMapsRoad"
          title: "Road"
        basemaps.push(basemapRoad);
        var basemapAerial = new esri.dijit.Basemap({
            type: "BingMapsAerial"
          title: "Aerial"
        basemaps.push(basemapAerial);
        var basemapHybrid = new esri.dijit.Basemap({
            type: "BingMapsHybrid"
          title: "Aerial with labels"
        basemaps.push(basemapHybrid);
        basemapGallery = new esri.dijit.BasemapGallery({
          showArcGISBasemaps: false,
          basemaps: basemaps,
          bingMapsKey: bingKey,
          map: map
Do I replace type: �??BingMapsAerial�?� with �??Ocean_Basemap�?�?  What do I use instead for id: �??bmRoad�?�?  I do not understand where type and id are coming from.  When I look at http://services.arcgisonline.com/ArcGIS/rest/services/ and go into the individual layers, I still can�??t seem to find similar items.  I realize the basemaps are already there, but it looks like I still have to define them to build the custom menu.  If there is a simpler way, I�??m game, but I am a beginner.
Thanks for your help!
KellyHutchins
Esri Notable Contributor
You'll want to follow the instructions on this page to create a group:
http://help.arcgis.com/en/arcgisonline/help/010q/010q00000016000000.htm
Once the group is created you can add web maps to the group that contain the basemaps you want to display. So if your organization has a basemap you'd like to add just create a web map with just that basemap added then share it to the group.
Kelly
Jose_FranciscoSánchez_Díaz
Really easy!
Thank you Kelly!
AndrewDavis
I have read the entries here and I am working with something similar, but having limited success.
I have my .api's (2.8) installed locally and running fine on my server.
I have 3 cached services which I would like to display in the BasemapGallery dropdown.  So far I have gotten two do display (Names of the services) in the dropdown button.  However, I am only able to get the first one to work on the click event.  This is a manually loaded gallery.
I am unsure of the changes I have made to the function.
//Manually creating a list of basemaps to display
var basemaps = [];
var myStreets = new esri.dijit.BasemapLayer({url: "http://myLittleServer/rest/services/myfolders/MapServer"});
var theStreets = new esri.dijit.Basemap({layers: [myStreets], title: "The StreetNetwork"});
basemaps.push (theStreets);
var myHouses = new esri.dijit.BasemapLayer({url: "http//myLittleServer/rest/services/myotherfolders/MapServer"});
var theHouses = new esri.dijit.Basemap({layers:[myHouses], title: "The Houses"});
basemaps.push (theHouses);
   basemaps: basemaps,
   bingMapskey: bingKey,
   map: map
//BasemapGallery.startup isnt needed because we aren't using the default basemap, instead
//we are going to create a custom user interface to display the basemaps, in this case a menu.
dojo.forEach(basemapGallery.basemaps, function(basemap) {
//Add a menu item for each basemap, when the menu items are selected
dijit.byId("bingMenu").addChild(new dijit.MenuItem({
   label: basemap.title,
   onClick: dojo.hitch(this, function() {
this.basemapGallery.select(basemap.id);
Why is there only one working service, and the second one does not display on the click event?
Andy...
JohnWall
Is there a way for me to add this thread to my favorites or something?
JanBenson
John,
  When you reply to a thread, below the text input window there are Additional Options.  Under Additional Options there is Subscriptions.  Here you can opt for email instantly, daily, or weekly.
BarryGuidry
How do you make the "Basemapgallery" drop-down menu collapse after making a selection within?
JanBenson
It should be built into the sample.  My button from the sample does collapse after I make a selection.  If I select the Basemaps button, but then do nothing, it will stay open until I click anywhere in the window.
KellyHutchins
Barry,
Something like this should close the dropdown after a selection is made:
      dojo.connect(bookmarks, 'onClick', function(evt) {
        dojo.query('.dijitDropDownButton').forEach(function(node,idx){
            var btn = dijit.getEnclosingWidget(node);
            btn.closeDropDown();
If you have multiple dropdown buttons in your app you'll have to tweak the code a bit to just get the one for the Bookmarks.
BarryGuidry
OK, I see, there is a difference between the samples. The one I started with, here, does not collapse automatically, and is a "digit.TitlePane" rather than a "dijit.form.DropDownButton" as this one.
BarryGuidry
Actually, I would like to copy the BasemapGallery functionality from the sample here, but cannot figure it out. There is a dojo requirement "dojo.require("myModules.custommenu")" that I guess cannot be utilized. Or, at least, can someone see how the "Basemaps" menu button collapses after changing the basemap? That is actually all I need to add to my code possibly.
