Why won't apply edits update, but adding a new point will for Features?
11380
22
05-22-2015 02:15 PM
ChrisSergent
My application will create new feature points, but will not update existing points. Is there different syntax besides the applyEdits to perform an update? I have debugged and the attributes are there when I start. They just don't take, which is why I thought my syntax may be wrong.
Here is a block of code that I am trying to use for one of the updates:
 // get sign attributes from form and submit
    var updateSigns = function () {
        // alert(domClass.contains("attributesSignModal", "in"));
        var attributes = {
            // TODO: not sure if this is needed
            //requestreceived: null
        var currentDate = new Date(); // current date is defined but never used.
        var graphic;
        graphic = new Graphic(app.currentGeometry);
        query("#attributesSignModal input, #attributesSignModal select, #attributesSignModal textarea").forEach(function (formInput) {
            attributes[formInput.name] = formInput.value;
        // Form validation - ensures that the values for the data are here if left blank
        if ((attributes.installed === undefined) || (attributes.installed === "")) {
            attributes.installed = null;
        if ((attributes.signId === undefined) || (attributes.signId === "")) {
            attributes.signId = null;
        if ((attributes.supportId === undefined) || (attributes.supportId === "")) {
            attributes.supportId = null;
        graphic.setAttributes(attributes);
        stopCaptureRequest();
        console.log(attributes);
        app.signLayer.applyEdits(null, [graphic], null).then(function (response) {
            console.log(response);
            app.signLayer.refresh();
and here is an addSign that does work:
    var addSigns = function () {
        var attributes = {
        var graphic;
        query("#attributesSignModal input, #attributesSignModal select, #attributesSignModal textarea").forEach(function(formInput) {
        if ((attributes.installed === undefined)|| (attributes.installed === "")) {
        app.signLayer.applyEdits([graphic], null, null).then(function (response) {
and finally, here is my latest github commit:
csergent45/streetSigns at 787b3ed59a446ca1cfcb8229d696b3445c4dda59 · GitHub
Tags (1)
ChrisSergent
I've checked this. All items have an OBJECTID. Or do you think I need to include this on my form?
BethManghi
Try including it in the form so that it gets passed with the updated attributes.
ChrisSergent
This didn't work. With my latest updates I get this error message: error.png
and I have updated my project here:csergent45/streetSigns at 119dc2ec277a347c066f92fa13e0ca76f182fb8f · GitHub
KellyHutchins
Esri Notable Contributor
In your app it looks like you create a new graphic for the update feature operation. If you are updating an existing feature you should already have a graphic. So instead of creating a new one just get the existing one and update what has changed (attributes or geometry).
ChrisSergent
I am just updating the attributes, but I don't see how to exclude the graphics.
KellyHutchins
Its not a matter of excluding the graphics its a matter of updating the existing feature (graphic) rather than creating a new one.
ChrisSergent
Would taking new out work then for that?
KellyHutchins
No.  How are you determining that the feature is being updated? Is the user clicking on it? If so then the click event should give you access to the feature that is being updated.  If you look at the API reference for the Feature Layer click event you'll see that the returned object includes the graphic that was clicked.
FeatureLayer | API Reference | ArcGIS API for JavaScript
OwenEarley
Is your app.currentGeometry variable an existing graphic object that you have already obtained from the feature layer?
If this is the case you should be able to just modify its attribute values and apply the edits:
            app.currentGeometry.attributes.installed = null;
            app.currentGeometry.attributes.signId = null;
            app.currentGeometry.attributes.supportId = null;
        // graphic.setAttributes(attributes);  <- no need for this as attributes are assigned directly to the updated object
        console.log(app.currentGeometry.attributes);
        app.signLayer.applyEdits([app.currentGeometry], null, null).then(function (response) {
As Kelly Hutchins​ points out you send the existing feature when making an update.
ChrisSergent
I see what you and Kelly Hutchins​ pointed out, but when I comment out that line the point won't update. I received a response from twitter that updated my code on github with the following that made my application work:
        var attributes = {
        var graphic;
        attributes.objectId = parseInt(attributes.objectId, 10);
Line 41 was added to remove quotes and I needed to keep line 43. Whenever I took line 43 out, there were no updates. In addition I had to add app.signLayer.refresh(); after the  app.signLayer.applyEdits block to refresh the layer so that updated data would display when clicking on the map points.
