Why is esriRequest not working?
8750
10
05-23-2019 05:26 AM
JustinBridwell2
I am trying to use esri/request to pull in some data from an API. I am have two weird problems. First, when I try to run this, it doesn't complete and throws the following error in the browser console: "Uncaught TypeError: Cannot read property 'trim' of undefined". I am not using trim()anywhere and am not sure why this error is being thrown (specifically on the line where I make my esriRequest). Second, if I try to test this in the browser by pasting in the function to the console, it says that esriRequest is not defined. I have checked the order of my required list and functions several times and they look like they are in the proper order. Am I missing something here?
require([
"esri/map",
"esri/basemaps",
"esri/dijit/BasemapToggle",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/tasks/ImageServiceIdentifyTask",
"esri/tasks/ImageServiceIdentifyParameters",
"esri/layers/WebTiledLayer",
"esri/dijit/Search",
"esri/config",
"esri/request",
"dojo/json",
"dojo/promise/all",
"dojo/domReady!"], function(
Map,
esriBasemaps,
BasemapToggle,
ArcGISDynamicMapServiceLayer,
ImageServiceIdentifyTask,
ImageServiceIdentifyParameters,
WebTiledLayer,
Search,
esriConfig,
esriRequest,
JSON,
all) {
var url = "https://earthquake.usgs.gov/ws/designmaps/asce7-16.json?latitude=18&longitude=-66&riskCategory=I&siteClass=D&title=Default";
esriRequest(url, {
    responseType: "json"
 }).then(function(response){
// The requested data
    var seis_data = response.data;
RobertScheitlin__GISP
Justin,
  Most likely you are trying to access the results before they have returned then. You have to understand the nature of a async call.
