Why Height Restriction is not working
5407
05-03-2015 03:10 AM
AshishRao
routeTask = new esri.tasks.RouteTask("http://route.arcgis.com/arcgis/rest/services/World/Route/NAServer/Route_World");
routeParams = new esri.tasks.RouteParameters();
dojo.connect(routeTask, "onSolveComplete", showRoute);
routeParams.restrictionAttributes = ["Use Preferred Truck Routes","Height Restriction"];
routeParams.attributeParameterValues = [{
"attributeName": "Use Preferred Truck Routes",
"parameterName": "Restriction Usage",
"value": "Prefer_High"
"attributeName": "Height Restriction",
"parameterName": "Vehicle Height (meters)",
"value": 40000
routeParams.outSpatialReference = { "wkid": 102100 };
if (li.length != routeParams.stops.features.length) {
                    var x = locationPoint[li.length - 1].getLatitude();
                    var y = locationPoint[li.length - 1].getLongitude();
                    var latlog = new esri.geometry.Point(y, x);
                    var webMercator = new esri.geometry.webMercatorUtils.geographicToWebMercator(latlog);
                    var point = new esri.geometry.Point(webMercator.x, webMercator.y, new esri.SpatialReference({ wkid: 102100 }));
                    var graphic = new esri.Graphic(point, stopSymbol);
                      routeParams.stops.features.push(new esri.Graphic(point, stopSymbol));
if (li.length>=2) {
routeTask.solve(routeParams);
    function showRoute(solveResult) {
        clearRoutes();
        dojo.forEach(solveResult.routeResults, function (routeResult, i) {
            routes.push(map.graphics.add(routeResult.route.setSymbol(routeSymbols)));
// For addres: 550 C St SW, Washington, District of Columbia, 20024 (here is tunnel)
//to 500 5th St NW, Washington, District of Columbia, 20001
ESRI Please Help
AshishRao
I Resolve this by replacing the code with
  var graphic = new esri.Graphic(latlog, stopSymbol);
AshishRao
SepheFox
Isn't this question cross-posted elsewhere on the forum?
AshishRao
No Sephe, but what you need actually?
SepheFox
I need you to mark your other question as answered also:Why Height Restriction is not working. Thanks!
