Why don't my navigation tools work once I place them directly on my map?
1762
10-03-2014 12:38 PM
TracySchloss
Honored Contributor
I just want to use a few of the Navigation tools, Zoom Previous and Zoom Next.  I had this originally placed in my right side pane.  Where I really want them in tucked up into the upper right corner of my map.  I added a div to my map, placed the buttons there and changed my entries in CSS to an absolute position to stay where I want them.
Every thing looks fine, until I add the click listener to the buttons.  Then not only does the display go wonky (side panel disappearing is the most obvious) but I'm also getting a registry.byId error on the id of my buttons.
Here's the relevant code:
map = new Map("mapDiv", {
basemap: "topo",
center: [-92.1, 38.5],
infoWindow:popup,
zoom: 7
navToolBar = new Navigation(map);
navToolBar.on("extent-history-change",extentHistoryChangeHandler);
//FUNCTIONS FOR NEXT, PREVIOUS AND HOME EXTENT BUTTONS
function extentHistoryChangeHandler() {
   registry.byId("btnZoomBack").disabled = navToolBar.isFirstExtent();
   registry.byId("btnZoomForward").disabled = navToolBar.isLastExtent();
//event listeners
registry.byId("btnZoomBack").on("click", function(){
        navToolBar.zoomToPrevExtent();
   registry.byId("btnZoomForward").on("click",function(){
        navToolBar.zoomToNextExtent();
CSS:
#navDiv {
  display:block;
position: absolute;
top: 12px;
right: 12px;
z-index: 999;
opacity: 0.4;
#navDiv:hover {
  opacity:1.0;
.navButton {
height:12px;
font-size:3px;
font-family: Arial, Helvetica, sans-serif;
.zoomprevIcon {
background-image:url(../images/nav_back.png);
width:32px;
height:32px;
font-size:8px;
.zoomnextIcon {
background-image:url(../images/nav_next.png);
width:32px;
height:32px;
font-size:8px;
HTML
  <div id="centerPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'" style="padding:0;">
  <div id="mapDiv" >
   <div id="navDiv">
    <button id="btnZoomBack" data-dojo-type="dijit/form/Button" data-dojo-props="label:'Previous Map View', iconClass:'zoomprevIcon',showLabel:false" type="button"></button>
    <button id="btnZoomForward" data-dojo-type="dijit/form/Button" data-dojo-props="label:'Next Map View', iconClass:'zoomnextIcon', showLabel:false" type="button"></button>
</div>
<img id="loadingImg" src="images/loading.gif" alt="Loading image" style="position:absolute; left:350px; top:250px; z-index:100;" />
    <div id="HomeButton"></div>
    <div id="floater_report" data-dojo-type="dojox/layout/FloatingPane"
    data-dojo-props= "title:'Search Results', dockTo:'dock_report', closable:false, resizable:true, dockable:true"
    style="visibility:hidden;"  >
         <div id="reportContainer" data-dojo-type="dijit/layout/ContentPane" > </div>
    </div>
   </div>
  </div>
Tags (1)
HungTruong
Tracy,
I think FloatingPane causes the issue. You add "dojox/layout/FloatingPane" in your require statement, it will work fine, as shown below:
require([..., "dojox/layout/FloatingPane"], function(...){
Hope this help.
HungTruong
Tracy,
Hope this help.
TracySchloss
Honored Contributor
Since everything else worked, it didn't occur to me to add this.  It's fine now.  Thanks so much!
