Why does my code stop working if I add "esr/dijit/Geocoder" in my require section?
3784
09-28-2014 02:56 PM
NewOutlaw
I have this in my code initially:
        require(["esri/Color",
          "esri/map",
          "esri/graphic",
          "esri/graphicsUtils",
          "esri/tasks/Geoprocessor",
          "esri/tasks/FeatureSet",
          "esri/symbols/SimpleMarkerSymbol",
          "esri/symbols/SimpleLineSymbol",
          "esri/symbols/SimpleFillSymbol",
    "dojo/domReady!"
    ], function ( ..etc..)
Now if I add one line in between map and graphic:
"esri/dijit/Geocoder",
my code stops working!
Any thoughts as to why this happens please??
OwenEarley
Have you added the Geocoder function parameter as well?
  "esri/map",
  "esri/graphic",
  "dojo/domReady!"
], function (Color, Map, Geocoder, Graphic, etc)
AlexeiB
If you 'define' it last (before domReady!), does it work?
OwenEarley
  "esri/map",
  "esri/graphic",
  "dojo/domReady!"
