Which service to use and when
1428
08-22-2013 07:34 AM
vinayb
HI All,
  I am starting with ArcGis for our application.I am not sure when and how do these matter.When i look at api reference there are so may api .Layer,dijit ,geometry , geocoder .If i want to display map and have interactive feature on this which service should i use.
ShreyasVakil
HI All,
Follow this sample to display a map. If you want to just show your data on map, you can use ArcGISDynamicMapServiceLayer.
Sample which shows how to add a DynamicMapServiceLayer.
There are different classes for different functionality, if you wish to add Geocoding to your applicaiton, then you can use the Geocoder widget.
If you want to perform some analysis/operation like buffer, project, distance etc. , you'll have to use the GeometryService.
If you want to query your data and show it in a popup window, you'll have to use a QueryTask.
It you want to add editing capability, you'll have to use Editor Widget.
vinayb
Can you please tell me what is the difference in using feature layer service and ArcGisDynamicMapService.Should i be using these to display the map or by using this i get access to service provided by rest .
  Can i use querytask to query both of service mentioned above.Are all other service other then these to are used for mostly to do client side functionalities.
ShreyasVakil
Basically, the usual workflow is to add a basemap which is a tiledmapservice layer. Then we add either ArcGISDynamicMapService layer and/or Feature layer. Using feature layer you get access to your data, feature layer gets the data back to the client while a DynamicMapService layer gets snapshot of your data in the form of a image to the client and not the actual data.
Query Task is independent on the service you are using. QueryTask is performed on a specific layer to query/filter data and get it back to client.
Please go through the documentation here for QueryTask.
Feature Layera are also explained nicely here.
