Where is the Map Notes web application
1014
09-26-2013 01:25 PM
JoseSanchez
Hi all
I am taking a look to the Map Notes sample, and I would like to download the code to test it locally
http://www.arcgis.com/home/item.html...b7f6d132338620
What I do not understand is how do I install this application, because on the download there is only a File Geodatabase and a mxd.
How do I run this link with my own data:
http://www.arcgis.com/apps/OnePane/b...e9195c2ddf94a6
Thanks
JonathanUihlein
Your links are broken but I noticed you've already opened a thread on this topic in another area:
http://forums.arcgis.com/threads/93446-Where-si-the-Map-Notes-web-application
Fixed Links:
http://www.arcgis.com/apps/OnePane/basicviewer/index.html?appid=74ff72a794394ed68de9195c2ddf94a6
http://www.arcgis.com/home/item.html?id=25db16cfe7b64501a0b7f6d132338620
Unfortunately, I do not know the answer to your question.
