When the 'onExecute' method is executed?
2200
10-18-2016 08:47 AM
RolandoFlorez
When I have a featureAction in my widget, the onExecute method, when is executed?
I know that Is not when I open the widget, somebody knows when?
RobertScheitlin__GISP
Rolando,
   You have to build one yourself. You can look at the eSearch widget for an example of this.
Widget.html:
<div class="popup-menu-button esearch-result-action-button" data-dojo-attach-event="click:_onBtnMenuClicked" data-dojo-attach-point="divOptions" title="${nls.resultactions}"
        style="display:none;"></div>
Widget.js:
  _onBtnMenuClicked: function(evt){
        var position = html.position(evt.target || evt.srcElement);
        var featureSet = this._getFeatureSet();
Rolando,
   When the custom FeatureAction is clicked. It depends if the FeatureAction is added to the popup menu or a menu in the widget itself.
RolandoFlorez
Robert, and how can I use  a menu in the widget itself.?
Rolando,
Widget.html:
Widget.js:
