When I add locale to URL the application requires login
1168
03-05-2019 04:06 AM
DanielChristensen1
Hello,
I have a custom web application that I'm working on.
It is based heavily on the boilerplate from: configurable-app-examples-4x-js/webmap-ts at master · Esri/configurable-app-examples-4x-js · GitHub
Besides that it has a custom layer control widget.
When I load the app it works fine. But as soon as I add "&locale=en", it prompts for login to the portal.
Can anyone explain to me why, or what I can do about it?
DanielChristensen1
Apparently if I click cancel several times I can get to the application again.
The console shows the following:
Note:when loading without locale defined it shows:
Notice the difference in language. For some reason it seems to ask for login when the locale is not danish (my default browser local), while just accepting that items are inaccessible if the locale if default danish.
Maybe this can help someone explain to me why this is happening.
DanielChristensen1
Apparently it's related to the default basemap group.
When I create a group in the Portal for basemaps, the application no longer requires login when locale is set.
