What PDF generators are compatible with Web AppBuilder
2556
11-23-2016 01:34 PM
WilliamMiller4
Hello,
I would like to generate PDFs in Web AppBuilder from data in the map, NOT make a PDF of the map image. I am wondering if anyone has generated PDFs in their Web AppBuilder apps, other than using  the Print widget? I have been looking at some PDF generators, like PDFMake, and am wondering how to incorporate this with the Dojo/ESRI APIs. Any help is greatly appreciate. Thank you for your time.
William
Tags (3)
Drew
We use SQL Server Reporting Services to build custom PDF reports.. Depending on the data and how we capture it, we have a middle tier .NET web service that does some pre-processing and more.
Drew
